On drilling holes for pulls in a bow front chest
Bill Tindall
If you have been following this adventure a previous installment involved wonderment as to how to drill the holes for the pulls on a curved surface. Anything but the correct hole orientation results in pulls that bind. This simple jig resulted in holes that were correctly spaced, parallel and most subtlety, perpendicular to the average tangent to the arc between the holes.
Two squares are used to locate the holes. (the clamp is just to hold the squares so I can take the picture) A prick with an awl marks the spot. After multiple checks to see the holes are indeed in the right place a shallow (1/4" deep about) pilot hole is drill at my best guess as to the correct angle.
Next the drilling jig is installed using two drills to align the jig with the shallow pilot holes previously drilled. The drilling jig is simply a "C" shaped piece of wood with two guide holes drilled perpendicular to the top surface and the correct distance apart.
After the holes are drilled the pulls are installed and they work as expected.
The location of the pulls was taken from a similar piece in the Connecticut Valley Furniture book (page 386)and the style was selected by my artist daughter. If it suits her it's fine by me!
Re: On drilling holes for pulls in a bow front chest
Bill, you have obviously . . .
Nathan
. . . mastered the higher mysteries of curved cabinetmaking. Congratulations. I'm still in the head-scratching phase.
By the way, nice piece. I'm sure it will make a fine addition to your daughter's room.
