ADVERTISE HERE - FREE TRIAL
Anyone fixed Gross Stabil clamps?
paul in AZ
Assembling a case today I had not one but two Gross Stabil clamps slip. They are the 1 meter [-~36"] size. I cleaned gunk out of the serrations & wire brushed them, disassembled the clamping mechanism, reversed the plate inside, and still nada! Then I took apart the distal end, pulled everything off and tried to flip the bar over but the bolt holes in the bar are wrong so it couldn't be reassembled that way.
Anyone with ideas on fixing these? Or do they go into the recycle barrel.
Re: Anyone fixed Gross Stabil clamps?
Take A Shot
At sharpening the serrations with a "V" file. Have you e-mailed the mfg'r?
Re: Take A Shot
paul in AZ
Gross Stabil clamps were bought out by Bessey several years ago. I called Bessey and was told that they shut it down, sold off all the product and there are no parts available. Also no service. Thats one way of gaining market share.
The thought of a small triangular file occurred to me but that bar material is pretty hard and there are a load of serrations to file out. I may still try it but not with much enthusiasm.
I'll try again to see if I can get access to the piece in the clamping head that grips the bar. That is the part that comes into play every time and it could be worn out. If I can get at it.
In the meantime I ordered a set of Woodcraft's clamps that were on sale. Made by Bessey, not as well as the real thing but at 4 for $100 worth a try.
clamps still  available  *LINK*
del schisler
you can still by them here is the web address
http://www.buycheapr.com/us/result.jsp?ga=us13&q=gross+stabil+clamps
