Padauk shortage?
Padauk shortage?
Padauk shortage?
Mark Mallia
Has anyone had trouble getting Padauk lately? I'm wondering if there is something going on in Africa creating a problem.
Re: Padauk shortage?
paul in AZ
I haven't looked at or for it lately but it is safe to say that there is ALWAYS something ugly going on in Africa.
Mark Mallia
I just hope it doesn't go the way of Wenge. I used to get Wenge for $6.50. then there was a civil war and it became unavailable for a while. When it came back it was $18.
Clint Searl
If there is...
Clint Searl
I certainly won't miss it. The one project I used it for, a mantle, covered my shop with persistent orange dust. And the mantle changed from the bright dark orange to a nondescript dark dark maroon.
Clint
Yonak
Unfortunately, a lot of wood in Africa, including padauk, becomes charcoal.
Re: If there is...
John Veerkamp
Try exposing the browned wood to uv light. Some of the exotics do the opposite of most woods. Try it on a scrap piece first, not on your mantle.
Re: If there is...
FredD
That clinging sanding dust from Paduk is toxic , so a good mask is in order when sanding it.
The few times I have used it , I sanded it out of doors.
FredD
Clint Searl
Good excuse for my personality
Clint Searl
Re: If there is...
John Paduak naturally ages to a rich burgundy color. I like it but you have to anticipate that in the final product and it takes a fair amount of UV light to change it. It will of course change by itself over a year or so.
If you really want to have fun try putting Paduak and holly side by side and then sanding them.
Re: If there is...
Mark Mallia
There is not a lot you can do to keep it from turning, except keep it out of the light. Armour All works, but the UV uses it up, you have to keep reapplying it every couple months, not really worth the trouble.
In addition to being something you don't want to breathe, the dust makes a terrific dye. In the summer when it's hot in the shop (my shop anyway) the dust combines with sweat and stains tshirts a bright orange.
Re: If there is...
del schisler
Why doin't you get some fan's and face to a open door way or put the fan in a window? Now take the air compreser and blow the dust to the open using a dust mask and get it out of the shop? I use a air comp. and blow all the dust out of my shop with a 36" exhaust fan that suck's all the dust out of my shop 12x20 . I blow the stuff that get's on the floor to the end of the shop and than blow it to the corner and suck it up with the shop vac. system. My shop is almost dustless. Good enough to spray lacquer with no dust in the finish. I been doing this for about 20 yrs in this shop. I clean up after each operation which keep's shop clean. Best to do it all the time and not let it build up.
Re: If there is...
Mark Mallia
I've found over the years (33 years pro for me) that it's not worth my time to clean the shop every day. While it's pleasing to look at the dust free shop on those occasions that I do clean it, I already spend 10 hours a day or more working there, so an extra half hour is a big deal.
Air management is a different issue. I don't use an evacuation system because of space restrictions, what works for me is an ordinary 36" box fan that is sealed to a sheet of plexiglass and fitted into a window, used as an exhaust fan. They only last a year or so under these conditions, they are designed for free flowing air, but it's still a lot cheaper than using the more expensive exhaust fans.
Re: If there is...UP date
del schisler
I have a exahust fan that i have use almot dailey for 15 yrs or so still working. I have 2 of them one by the leath so as to take the dust out the window. And i can use air and blow the dust or what ever get on the floor to the end of the shop and suck it up in 5 min or so. That is why i do it every time. I clean all my tool's also. I like to grab them and find them covered with dust and dust inside of the unit's. I havent had a motor fail in over 20 yrs that i know of. I have lot's of tool's you name it and i most likey have it and it is clean. I blow the motor's on my cont. saw and motor on band saw evertime also. Just a clean freak i guess . I like to have a clean shop. I have went into some and have to walk into saw dust and shaving's Not my kind of shop.
Mark Mallia
I like the sawdust on the floor, much easier on the feet than concrete, especially if you like to work barefoot like i do. Sawdust is clean and fragrant, not like dirt. I'm with you on the tools, though, I keep my motors blown out also. If you are using box fans that last 15 years, I would say you are probably not sealing them airtight into the window opening. Or perhaps you are just in a cooler area.
FredD
working barefoot in a shop ??
Sends chills up the spine.
I had a Neighbor in CA that like to power mow the lawn bare footed, I suggested she wear some protection on her feet ,so she started wearing Flip -Flops and not long after , ricocheted a English Walnut off her Ankle bone.
FredD
Mark Mallia
You should try it, it's very comfy.
I'm fastidious about my safety routines, I don't need a routine for not dropping things on my feet though, I just don't do it. Of course, I work alone and don't make big things like furniture or cabinets either.
FredD
I bet you never stubbed a toe either ;-))
FredD
It does remind me...
John in NM
Of once dropping a newly sharpened chisel and very foolishly sticking my foot under it to keep the sharp edge from smashing into the concrete floor - an amazingly stupid reaction (almost literally a knee jerk :D ) that I still marvel at a decade later. Not only did the edge still get quite blunted, I then had a nice cut in my steel toed boot :D
del schisler
These are exhaust fan's not box fan's and they are sealed real good. I been doing wood working for aprox 50 or so yrs. And have been around the block a few time's. And as far as saw dust on the floor it can be slick on concrete?? And no shoes if you happen to drop a piece of wood on the toe's don't that hurt or just been luck-ey? I guess to each his own. I got to go and make some saw dust.
