No Frills Cherry Sideboard *LINK*
Hikmet C. Sakman Victoria, BC CDN
This one is as simple as it gets. Your typical Shaker style. Solid breadboarded top, handles and knobs are cherry, from Lee Valley. Oil-varnish finish. 60'x24"x34" (WxHxD). I also made matching display case but I can't find the pictures in my laptop. I'll post it when and if I find it.
Chico...
Sakman Fine Woodworks
Re: No Frills Cherry Sideboard *LINK*
Singular or plural?
Nathan
Didn't you mean "we" made a matching display case - i.e. you and your army of clones, because I say that's the only way you can turn out all these beautiful pieces at such a fast pace!
Measure Again
Check your "H" and "D", Chico. They don't seem match up well with the image. :D
Very nice job, especially nice treatment on the two drawer-fronts
question
Bill Tindall
When a case piece has a frame and panel side and a drawer there is the problem of dealing with side and bottom drawer runners. How did you support the drawer and constrain it on the panel side?
Pretty wood.
Not Chico
But I've done the same thing using a 3/4" x 1/2" rail fixed to the two stiles. If the drawer were heavy and I still wanted side-hung (center guided), I would also fix the rail at the center of the panel as well which would still allow the panel to freely expand and contract from that center point.
Now, I'd probably use a Blumotion bottom-mount set without touching the side panels.
Kneale Brownson
Maybe that's why no middle/upper drawers?
Kneale Brownson
Re: question
I did not understand your question clearly. There's a horizontal divider in the middle (where you open the doors) which streches from side to side, adding great rigidity to the whole structure. Also a vertical divider is placed from the bottom (in between the drawers) all the way to the bottom of the top.
Doors and drawer fronts are overlapping that vertical divider in the middle, perhaps that gives you the idea that there's no vertical stop in the middle.
This cabinet structurally rock solid because of those vertical and horizontal dividers.
and yes, I used Blum Tandem slowmotion drawer hardware.
Chico...
Moses Yoder
Re: question
Moses Yoder
I have seen this done with a frame and panel dust panel below the drawers, only let into the front and back stiles on the sides. But like Mark, nowadays I would use a Blumotion slide with a support only at the back, pocket screwed into the rear stiles, wiht a rear mount brack for the slide.
Re: question
Bill Tindall
that renders the question irrelevant.
Think traditional drawers.......In a flat sided cabinet the drawer is constrained on the slide by the flat side of the cabinet. However, in a frame and panel sided cabinet the side is not flat and some additional framing is necessary to constrain drawer movement on the frame and panel side of the cabinet. I have not been able to pike into many of such cabinets to see what ways have been employed to constrain the drawer lateral movement.
Re: question
Bill Tindall
It's a personal thing but I don't like to open a reproduction cabinet and encounter modern hardware, especially so the huge hinge affairs that are used on kitchen doors. I find a traditional drawer that slides effortlessly with a push of a finger on one corner to be a particularly satisfying part of woodworking. But indeed, I see modern hardware all the time in shops selling recent made furniture.
