I've done four of them…
Rod Peterson�Ormond Beach, FL
Three were "click together" and the fourth was a glue down. Never again on the glue down. The adhesive was a nasty PL type and got on everything. Did a whole house (daughter's) with it, thus had some help. I'd have hated doing it alone.
The other three were one moderately expensive and two cheap. I don't particularly care for any of them, but when SWMBO says, "I want the floors covered"… The cheap ones definitely feel cheaper than the more expensive ones, and the surface is much more fragile.
Use the underlayment. It's cheap enough, and it'll provide just that much cushion to make the floors palatable.
I don't think it's possible to install the things without having to use some mechanical, sudden, inertial persuasion (hammer). Use scraps of the material to cushion the impact and protect the edges. Even doing so with the cheap stuff led to some damaged surface, so be careful.
Whether you start with a fresh saw blade or one that has some cuts on it, plan on resharpening after the job—the stuff is really tough on carbide. It might be worthwhile to buy an inexpensive big box blade for the job and then just toss it.
The biggest pain for me is undercutting the casings for door openings. I've used my biscuit joiner, but the cut is just a little too high, although workable. I have a "flip-over" offset handle dovetail saw that I use most of the time, but it's a knuckle buster.
You'll have to remove about half of your baseboard (and all of the shoe molding, if you have any). It'll become obvious why once you've started. When you finish, just reinstall the removed base, but when you install/reinstall the shoe molding, be sure to nail it to the base and not to the floor.
One word: knee pads. You'll spend a lot of time on them and you'll also be up and down a lot unless you have help to make the cuts. You can do the job alone, and a typical 13'×13' room can be done in a day, if you put in some time. I no longer enjoy putting in that much time, so I usually take two. Once the prep work is done, though, the field goes really quickly. All the rooms I did with the click type were bedrooms with closets, so cutting in those (and prep) almost doubled the time.
Rod
