OT Rolling Interior paint Question
Anyone paint the interior of a house with a roller? How do you cut in the corners? anyone use one of the corner rollers? Do they work well? Anything better than a brush?
I am having my son paint the interior of the house we are working on. This is a make work project to provide him with income. He hates painting nearly as much as I do so I am looking for ways to improve the process for him and me.
Re: OT Rolling Interior paint Question
There's another way?
You did say INterior, didn't you? I've used a roller for years for interior, and most people I know do too.
I cut in the corners and around the trim with a brush. The angled corner or trim brushes are the way to go; I use a 2" brush most of the time, although last year, I got a 1" brush for certain delicate details. Come out far enough that the roller can approach the corner/trim/wall without hitting it, and feather the paint out a little toward the field of the wall to minimize lap marks.
One of the advantages of corner brushes is that, with a little practice and a steady hand, you can paint a straight line up against trim by running the brush sideways along the trim. Easier to demonstrate than describe.
Besides the roller, buy a pole long enough that you can, if possible, paint the ceiling from the floor. This speeds up your work by a huge rate. Cut in the corners/edges/trim, set up your painting, and go at it with the roller.
Masking off windows pays for itself; rollers do make somewhat of a mess with spatter.
Also - this is a recent discovery on my part - painter's dropcloths SO pay for themselves. Get the heavy duty canvas ones.
Agreed
I've used the angled brushes many times. I prefer larger ones for cutting in around corners and ceilings and smaller ones for cutting in around windows and doors.
I borrowed a power roller once. I wouldn't buy one, but if I were to have to paint a number of rooms the same color, I'd consider renting one.
steve mackay
One of them corner dealies followed SWMBO home the last bedroom we did. "OH, this will make it easy". It didn't. MUCH more frustration (and swearing) than a brush. And the brush is faster.
FredD
If your painting , go at it like Painters do and you may actually enjoy it.
Get a couple of brushes for Latex or water based paint paint , both angled Sash brushes , one 1 1/2" for cutting in trim and switch and light boxes and anything hanging out of the ceiling and a 2 1/2" for cutting in ceilings or maybe spring for a hockey stick brush that lets' you stand on the floor while cutting in the ceiling.
If the ceiling gets painted , do it first, do not use the wall paint for trim paint, buy trim paint like Latex enamel.
A five gallon bucket and painters roller grid.
Good quality roller and roller covers with a 3/8th" nap.
lightweight canvas drop cloths if you plan on using them more then once, plastic covers if not.
I have always done a lot of painting and I keep 48" heavy canvas runners for against the wall and down hallways. They won't trip you like light weight ones..
i keep the plastic bags the roller covers come in and if I have to stop for lunch or overnight , just slip one over the wet roller cover and it will stay ready to use without the hassle of cleaning it every time you stop.
A adjustable roller handle is well worth the cost, or just a threaded wood handle five feet long will do.
Wear your old clothes. Explain to Son ,about not walking in wet paint and tracking it all over.
FredD
From 1971 to 1986 I was a builder and we painted the houses ourselves. That's pretty much how we did it. Good quality brushes and rollers and extension poles. Drop clothes where necessary, but generally painted them before the carpet and floor covering went in. I was just wondering if I had missed something. Had some worthwhile device for doing the inside corners come along and I missed it?
What about airless sprayers *LINK*
Stuart Johnson
When I painted our converted garage I used a Graco airless sprayer similar to this one. It was a first time use and I was pretty messy but will at some point need to do the rest of the house. I prefer having a colonoscopy to painting and the prep work isn't much worse.
Graco Airless
one more suggestion....
Bill Tindall
buy the best quality cover for the roller. The slow step is getting paint from can to wall. The best rollers hold so much paint they become tiresome to lift at the end of the day.
...I love to paint. It is instant gratification to see the improvement develop as the paint goes on. Get good with a brush....makes things go faster.
BTDT
Neal in San Jose
Twice! The spraying isn't the time sink, it is the prep/masking, etc. The first one was a small 3 bed/1 bath that had been totally trashed. I was replacing the carpet, so that wasn't an issue. Both times I removed all doors and dealt with them seperately. The second one was a 2 bed/2 bath condo where I was saving the carpet, so I now own about an acre of drop cloths!!! I was doing the ceilings in both or I probably would have rolled them, but I hate trying to paint pop corn ceilings. The condo had 16 foot cathederal ceilings which would have been a serious problem with a roller.
Make sure EVERYTHING you don't want painted is masked - windows, trim, vinyl floors, appliances, etc. Removing things like registers and doors is best. Use painters plastic to cover door openings into the kitchen and bath if you are doing that later in semi-gloss, etc.
Leave a window open and put a cheap box fan on the opposite side of the house to force some ventilation. Tape on some cheap furnace filters so you don't paint the entire neighborhood, and change the filters periodically. Don't even think about doing it without a GOOD respirator. Buy one of those cheap painter's suits and have at it. You'll probably want to take breaks often to let the fog clear up. IIRC, masking/prep took on the order of two days and the painting was something like 3 hours. Oh, and carry a brush in your back pocket to deal with runs/sags as they occur.
It isn't as bad as a colonoscopy, but takes a lot longer.
Re: BTDT
FredD
A note about Popcorn ceilings , Neal may have come across this in SJ.
A good ceiling applicator will put a gallon of white Latex paint into five gallons of Acoustical mix, this prevents the Acoustical material from flaking.
Also it prevents what happened in a entire house remodel we did , the Painter sprayed the old Acoustic with new Acoustic in every bedroom and the hall way and then we went to lunch.
When we came back the homeowner's Wife was all excited , she thought they had bought a Pig in A Poke when she discovered the ceiling Acoustic in every room was laying on the floor in a single sheet.
Truly a amazing sight and caused by the water in the new Acoustic penetrating the old Acoustic which obviously had not been mixed with Latex paint and it released it all at once.
The client was a very understanding Lady and she actually felt sorry for us.
FredD
Gary Bindel
One thing I would recommend if you have a lot to do is getting an 18" roller. They're great as long as there are not a lot of narrow strips such as between a window and a perpendicular wall.
Wow! I wish ....
it was always that easy to get off the ceiling. Sure would make renovating the house with it a lot easier.
Re: Wow! I wish ....
FredD
Have you tried using a weed sprayer and hot water Barry.
At the very least , it keeps the dust down.
FredD
We tried a spray bottle with water and a surfactant. Very limited results. If it did not get wet enough you scraped and basically smeared it, ruining the appearance. Too wet and the paper on the drywall was damaged and start too fall apart, ruining it. I have had some of it come down easily, but it either does or it doesn't. I suspect the type that doesn't has the paint mixed in it or it has been painted, or both and the type that comes down easily was probably put up with no paint in it and has not been painted. May also be that the ceiling was painted first and the popcorn put up later.
I was building when the popcorn idea emerged. The Sheetrocker was really excited about having gotten the equipment. They treated it as both an opportunity to profit by charging for the popcorn and a way to save money not doing a very good job on the ceiling. In his excitement to sell me on the idea the sheetrock exclaimed that he could add glitter to the ceiling for nothing. I blurted out, "how much would it cost to have you leave off the glitter?" (visualizing it as tacky) He was crushed.
