Update on relay for WW machine
Carol Reed, Strawberry, AZ
Galen is the winner! His drawing I understood and it worked.
The problem now is that in my screwing around, I fried the solenoid so have another on order.
Stay tuned.
Stay tuned.
Re: Update on relay for WW machine
Galen Vetterick
Carol
Some solenoids you can replace the coil only and it will be cheaper. Not sure what brand and type you have. Some cheap units are disposable and you must replace it all.
This is an integrated unit. STC 4V110-06. A 4 way 110v solenoid with 1/8" pipe threaded ports. It will operate an DA air cylinder, the travel of which can be adjusted by moving the 'break' switch. I will call the company in the morning and tell them my tale of woe. I expect to have to order another solenoid. Part of teh learning curve.
Pictures as soon as all is working. All the other construction is complete. This is gonna be a cool tool!
Galen Vetterick
Sounds like a little block solenoid, maybe even cylinder mounted. Got to believe the coil only can be changed. Did you have the wrong coil? I see why you drew the break switch as you did if it is a travel stop and not a PB.
Does it balance the cylinder pressures to hold traveled postion and what reverses cylinder travel?
Agh! I'll wait for the video!
Glad your closer to the end. Oh! I've fried my share of electrical components including myself over the years.
Video! Really not in my skill set! But maybe a new challenge. Certainly I will post some pictures. Your imagination may have to supply the motion. LOL! Thanks so much for your help. Certainly opened a wild discussion - more so than I thought it would, but then the folks here never cease to amaze me.
