mass wood boring - forstner? jig?
avalon
got a friend who is into small birds and wants me to make 10-20 birdnests from logs.... so they would have a natural outside..
i have up to a 3.5 forstner, which is ok for tiny... but was wondering what to do if i needed to do 4 inch - 5 inch - 6 inch holes..
i could do them on the lathe, but the forstner bit on a drill press would be faster... i have a drill bit adaptor for my tailstock..
so i figured i could cut 6 inch logs on a bandsaw sled, using a strap to hold it down, but i was wondering how to hold a natural edge log vertically on a full size (my height) drill press... and how to repeatedly do borings...
the reason is he also sells birds accross the country and he wanted to know if i could make them as he might want to sell them... which means making a lot...
i wont even attempt this till i got it figured out... its a bit beyond my newbi brain..
Re: mass wood boring - forstner? jig?
the reason is he also sells birds across the country and he wanted to know if i could make them as he might want to sell them... which means making a lot...
Red flag here - you are talking natural logs - which means untreated. This is a REAL problem. This is a good way to spread disease and insects. If you treat the log sections this would mitigate the problem - but you would have to really inspect and treat each log. We are currently facing a lot of deforestation and tree disease - because people shipped untreated wood to various places.
To answer your other questions - I've seen 4" Sawtooth bits (MLCS). I've also seen hole saws up to 5". As far as holding your log sections - if they are flat on the top and bottom - a band clamp would work fine. I would make a set of spacer that would hold it a particular distance from the upright post of your drill press. I would use a band clamp and clamp it to the upright.
I'm going to throw out something really radical. How about doing them on the bandsaw with a thin blade. Cut through the side and cut out the middle. Then glue the gap back together the same way I've done bandsaw boxes. Other than blade flex which could make getting the circle out of the piece it should go really fast. It would have the added option of slicing the ends off the waste and gluing that back in for a completed hollow log look.
Agree with John -- bandsaw them
I've never seen Forstner bits in the 5" - 6" diameter range, and I'd be almost afraid to use one. For one thing, Forstner bits don't work well for endgrain drilling, and the forces and heat generated by a bit this size would be extreme. For another, you'd be limited to the plunge depth of your drill press, which might or might not be enough for the houses in question. You'd also need a way to hold the log sections firmly to keep them from rotating. That might be difficult to do without damaging the bark.
On the other hand, a bandsaw will core out a birdhouse in just a minute or so. You can even make a jig with a center pivot so you can slide the section into the blade and then rotate it on its pivot to cut a nice circular core. The birds don't care if the walls are perfectly circular and smooth.
FredD
I have never seen a forstner bit that large and woudn't use one if it was available, bandsaw is the way to go and if you haven't one , a good hole saw like a Milwaukee can be safely used , but you would still need to hog out the center,
FredD
Steve Strickland
Re: 6" Forstner?
Steve Strickland
You plan on selling your kids to pay for such a beast? A 1/2" carbide is a tool budget buster all by itself. Makes great holes though.
Myra in TN
And, if you treat the wood, depending on what you use, you could do damage to any birds who might actually use the houses. If you go that route, check with a wildlife expert before treating.
Re: Agree with John -- bandsaw them
If you are making working bird houses in which actual birds will live, you should consider leaving them very rough on the inside. Sometimes the birds use the rough surface for a toe hole so they can climb out. I made about a dozen for my son when he was raising wild ducks. We cleared the larger ones with a chain saw. Often started with hollow logs. Come to think of it, there may have been two dozen. The surface left by a bandsaw might be too smooth.
