We value your privacy.
When I cleaned out a closet I found a box with several bags of different shellac flakes. I'm not sure when I purchased them but it was probably around 2000 or 2001. They were stored in plastic bags in a cardboard box with normal house heating and cooling. They are loose with no clumping. Will they still be good?
... is that esterification -- the process that gradually makes shellac useless -- begins when the flakes are dissolved in alcohol. The flakes themselves seem to last a good while, though I'm not sure if water vapor has a negative effect on them. I'd prepare a test batch and see how long it takes to dry hard and whether it compares with fresh shellac.
... shellac flakes last almost forever. It's best to seal them in glass air tight containers and store them in a cool or cold place for maximum longevity. Some finishers put them in a refrigerator. Plastic or plastic bags are not air tight.
To test, mix up a small amount in newly purchased alcohol and then apply to a sample board. If the flakes dissolve in the normal time and the resulting samples dries hard in two hours, the shellac is good.
Storage conditions have much to do with the process of esterification. For best results, cool, dark, and sealed seems to be a winning combination. I've held dewaxed flake material for more than 6 years with no ill effects on the resin. Dewaxing the shellac may have an added benefit because the wax content, even in dry flake form , is somewhat hydroscopic making it attract moisture and water vapor.
Regardless of how long you've held the dry flakes, you should always test a fresh mix before use. You have no way of knowing how long and under what conditions the material was handled before you received it. I crush/grind a quantity of dry flake in a mortar and pestle and then mix with fresh DNA. The powder will dissolve very quickly. I then apply two coats to a closed-pore wood. Next morning see how it sands with 150 grit paper. If it powders well and doesn't corn or load the abrasive, it's good to use. Others drip a puddle onto a glass surface and then check the dried resin the following day.
Last point here, mix only what you'll use, and don't store mixed shellac more that 3 months. Held more than a few weeks, run mixed shellac through a coffee filter and discard any amount that won't pass through. The filtered solution will have far more clarity.
If it's a question of moisture, there is a theoretical chance that the shellac could still be good.
You are undoubtedly correct that plastic is not air tight, but plastic does slow air circulation way down. And, depending on the type of plastic bags used and how the bags are closed, it can completely stop it. I know this from experience - from our builder I learned that if you put X (e.g. bags of cement, tubes of caulking, or whatever) in several plastic bags, tightly closing each one with a twist-tie, you can extend the storage life from weeks to years.
One bag is not enough, though. I tried this method with half-full tubes of installer's glue. I triple-bagged them, then stored them in a box for two or three years and when I opened them recently I was able to pop them in the gun and use them. Next to them in the box I had another tube of glue (seal broken) that was not bagged. It was hard as a rock.
Hopefully someone will find this method useful, as I have.
The shellac may or may not be good the only way to determine is to try an mix up a bit of each and see if they dissolve. The more processed the shellac the less shelf life it has. However under proper storage conditions protected from moisture, heat and light can preserve the flakes for a longer period of time.
Don't throw it away, you can always make Shellac Sticks for repair or Sealing Wax.
The only type of shellac that has unlimited shelf life is stick-lac or seed-lac, that has not been processed.
My understanding is that if undissolved shellac in big thick pieces was prone to oxidation/degradation in 10 years, the thin layer of shellac finish (after being subjected to dissolving, storage as a solution, drying) would not have lasted even 5 years.
If the flakes aren't stable in the can, or bag or what ever container, would not the shellac coating applied from such shellac flakes also be unstable. In other words, it would seem the film applied to the furniture would decompose or alter as much or more than the same stuff in the original flake form. Yet we know that shellac finishes are exceptionally long lived.
This is no place for logic or linear reasoning. Experience does not count against science. You KNOW that when you mix the flakes in alcohol that the reasole combines with the creasesin and the water boils off, leaving the mix unstable in the liquid form but very stable when slathered on wood. Its the gums (chickle) in the wood that are responsible for the mustafication. Mustification is the reason antique restorers and other charlitan junk dealers coat the inside of pieces with shellac to obfuscate the musty smell.
Chickle is what they make Chicklets out of which are coated with shellac to make them shiny.
Better check the connection on your fagioli, you may have a slight leak there. Besides, everybody (who's anybody) knows that tziktli ain't everywhere; they only come from the Chickle Tree.
