Wood thickness question - thick enough??
In my thoughts/plans for some shelving, I have a center upright. The upright is 3/4" thick x 11 3/4" wide. I was planning on using a stopped, sliding dovetail to connect the top, middle and bottom shelves to the side uprights and the center upright.
If I have two dovetails on either side of the center upright, this would give me an area that is ~1/4" thick x ~1/2" tall in the top, middle and bottom of the upright.
Most of the load will be vertical. Probably little or no side load. I will be attaching 1/4" plywood to the back of the center upright, the side uprights and the top, middle and bottom shelves.
Is this thick enough or should I consider making my dovetails less deep? I was planning on making them 1/4" deep.
TIA.
