Questions on UPS for Computer OT
I bought a UPS with my new computer. It advertised it had 120 minutes of backup power. Not so much. It seems to have more like 20 minutes. I did not think this through. This is little or no help. Unless I am home and awake it just delays the inevitable briefly. If I am sleeping and the power goes out, I don't hear the alarm. If I go out I don't hear the alarm. My power has been off four or five times recently. To say I am annoyed is an understatement. So, why does the thing say 120 minutes when that is a fantasy? What good is it? Why don't they make it so that it sends a signal to the computer to tell it to shut down on its own? What would you have to buy to get one that lasted long enough or did an auto shut down?
Re: Questions on UPS for Computer OT
Re: What did you get?
It says Tripp-Lite On the front. I have no idea what the model is.
John McGaw
"Why don't they make it so that it sends a signal to the computer to tell it to shut down on its own?""
Every one I've seen for decades has had signaling capability and software to support the most popular operating systems. On the wild assumption that you've bought a new, off-the-shelf, UPS there is probably a CD included which will have the software and virtually all of them will have a USB cable which connects to a connector on the UPS and one on the back of the computer. Old-time UPS units often had a 9-pin or 25-pin 'D' connector which often used some bizarre signalling scheme but these are all history now and and everything now uses USB connection.
"What would you have to buy to get one that lasted long enough or did an auto shut down?"
Lasted long enough it not a viable standard. Two weeks ago we had a wicked storm and 120k+ customers lost their power. Some, like my neighbor up the shared driveway, didn't get theirs back for six days. For that sort of support you want to consider a generator, not a UPS. If you really need super long-runtime when the AC mains fails then you probably want a low-power laptop with an oversized battery and a solar panel with suitable charging hardware to keep it juiced up.
I have [doing slow mental count] six UPS units [mostly made by Cyberpower] hooked up to various things around the house. The biggest four are rated at 1200W or 1350W which means that they can put out that much power for a short time but they will support a quarter of that for maybe 20 minutes before signaling the attached computer to shut itself down.
Please take a look inside the packing from your UPS and tell us what you find and tell us what the model is and probably somebody will be able to offer some assistance.
Jason Roehl in Lafayette, IN
My UPS (An APC brand unit) has an USB cable to talk to the computer. I can configure it to shut down immediately (and safely), or let it run until the battery is almost dead. Some of the receptacles on it are tied to the battery, others are just pass-through (would go dead in a power outage). Only the essential things are plugged into the battery back-up receps--CPU, monitor, router, cable modem.
It's interesting, though. When my laser printer spools up, it causes enough of a voltage drop to trip the UPS (it also is set to filter out voltage spikes and dips).
If you knew the model # of your unit, I could at least look it up online to see what it should be able to do. It's probably on the bottom somewhere.
Jason
Another Ignacy on my part.....
I hooked this thing up according the the quick start directions and never got any further than that. Now that I have been justly chastised by those who know far more about this than I do, I went back and read more thoroughly. The booklet that came with the unit said I might or might not have gotten a USB cable and might or might not have gotten a CD with the system. A little searching revealed I got the cable but apparently did not get a CD. I plugged up the cable but the system did not react and apparently did not recognise the new equipment. The booklet said I could go on line and get more information. I did that and found their down load site, but was overwhelmed by the choices. (does not take much to overwhelm me when it comes to computers.) I have sent them an E-mail with a question about what to download. I tried using the numbers on the sales receipt for a model number but no go. I can't find a model number on the unit or booklet or other papers. I am in no mood to be overwhelmed. My power has been off five or more time in the last month. I am considering scheduling a repair/restoration in advance of the next one just to have them on call. Its been off so much and so frequently it takes a while to figure out whether we are discussing this outage or a previous one.
Re: Another Ignacy on my part.....
John McGaw
I know what you mean about the frustration of power outages. I live in an old neighborhood overgrown with gigantic trees which the utility company is supposed to keep trimmed, and which they claim to have trimmed at great expense every couple of years, but which never actually seem to get trimmed and which kill power somewhere with every storm. The new power infrastructure dates back as far as the mid-60s and the oldest goes back to the Great Depression (1937 to be exact). It sometimes seems as if a flatulent squirrel could knock out power by blowing branches around. Actually my own power was taken out a few years back by a self-immolating squirrel sacrificing himself on the transformer which supplies just my house and one street light -- I was out of town, nobody else could tell that my power was gone, and a lot of expensive frozen steaks and salmon went out in the trash when I got back.
If you look at the packing materials for your UPS there will probably be a barcode printed on the cardboard box which gives the UPC and little sticky label which gives the serial number, model number, and manufacturing batch -- these are probably described on the mail-in warranty card. Failing that, if you can tell us what the maker is, what the power output is supposed to be, how many outlets it has, possibly where you bought it, and what your computer operating system is we can probably figure out what software you need to download. Digital pictures of the UPC barcode and sticky label would earn bonus points.
Bill Turpin WNC mountains
UPSs are rated in watt/hours. Most of the cheaper(actually less expensive) ones are designed to allow for a save of open docs and a routine shutdown. This is 5 to 10 minutes. Add up the watts of everything that is plugged in...monitor, computer, printer, router, modem, speakers, wall wart power supplies, etc. Do the math. Then deduct about 20% for the lies and aging batteries. It takes serious money to get anything longer.
Dave Paine
Barry, sorry you are finding out the hard way about the UPS ratings.
As another reply stated, big difference between max output and sustained output.
It helps to reduce the power drain. Do your monitors go into low power mode when not used? Check the "Power Management" setting in Windows. You want to be putting monitors into low power mode. The monitor can draw the most power for a single piece of equipment.
I have become familiar over time. These days when I need to purchase a new unit I get the largest I can afford.
I got mine due to frequent "blips". Many a second or so, maybe few seconds. Sufficient to cause some hard drive failures.
The units typically have alarms. Mine has USB and software, but sometimes the software stops being able to detect. I rarely reboot my XP PC. After a re-boot it normally detects, but after going into Stand-by it may not detect.
A newer version of Windows, e.g., Windows 7 may detect your UPS, but it seems your present version does not. Hence you need to find which version to download. It is frustrating when you find many selections and not easy to determine the correct choice.
Good luck getting your UPS to shut off Windows.
Stuart Johnson
There is also an issue with UPS being compatible with the equipment. I returned two UPS units because they would not work with my Dell. It turned out the units were good but some sort of electrical signal needed to be within a narrow range that only very expensive UPS handle. I've gone to a good surge protector and frequent backups rather than spending close to a third of the cost of a new P.C.
I don't know about 120 minutes, but
Henry Higginbotham
At work (when there's work), my computer has an IBM-badged version of the APC SmartUPS 1000. We got it as a refurb with a supposedly new battery from refurbups.com, although they no longer seem to have any.
Several months ago, the power went out and I continued working for 61 minutes in AutoCRUD with two monitors running. When the power came back on after the 61 minutes, the UPS had not yet complained of low battery power.
The box is long gone.
I actually bought this thing about a year ago and did the quick hook up as described in the literature. Until recently I rarely had power outages, maybe once every two or three years, now they are getting to be almost daily. So, I "invented" the scenario where the UPS would send a signal to the computer only to learn I was not the first to think of that. Then I read deeper into the literature and found that my device may or may not be able to do it and may or may not have the cable and may or may not have the software. Apparently they write one booklet and send it with all their units. I went to the web site to download the software and what I found was what appeared to be about five revisions of the "Windows" software with progressive dates. I was stymied by whether to down load only the newest one or to start with the oldest and progressively update it by downloading them in turn. Of Course this comes to me on Saturday evening and the company is only responding 9 to 5 weekdays, like anybody would have a question about an UPS any other time. We all know that power failures only occur during normal business hours.
The other side to the problem is that I just had a run in with the power company when they charged me a $600 deposit on the house I bought at foreclosure. It turns out the people who lost the house had not lived there in a year and a half and had not paid their final bills. So Dominion Power says I have to pay a huge deposit. But, not to worry, after I rent the house and they take over the electricity at that address, and I wait a year, I can apply for my deposit back. Since then my power at my residence has been off at least five times. I know they have nothing to do with each other, but if I am going to pay a huge deposit, I expect them to live up to their end and actually provide power 24/7. On the one hand, I know that's unreasonable, but on the other, I pays the money, I expect the service.
Power Deposit
Stuart Johnson
Barry, Is the $600 the normal new user deposit or the amount required because the prior owner was delinquent? Start up the food chain using your own home, usage and payment record to get it waived. Everyone has a boss and at some point someone will probably say yes if you are being polite but insistent.
Re: The box is long gone. *LINK*
John McGaw
If you are running Windows then the newest version of Tripp-Lite's software should do you fine:
PowerAlert Local (PAL) Software 12.04.0053 for Windows
19 Mb Last Update: Jun/15/11
It is up near the top of their download page.
http://www.tripplite.com/en/support/downloads/index.cfm?txtArchive=0&txtLang=&txtOS=
Re: Power Deposit
This is one of the things I intend to work on. The person I talked to told me they require a deposit on all new accounts and could not waive it since the last person at that address abandoned the account when it was delinquent. I pointed out that they were punishing me for something those people did and they called it was based on that address and the account history there. But, the amount was based on 2 1/2 times the highest two months of power usage at MY address in the last two years. The spread the $600 over four months. I got the first bill. $150 for the deposit. $15 reconnect fee because they had to cut the lock off the meter base. $5.95 local county tax. Some other small fees and a little less than $3 for the actual electricity. Their are two aspects of this that are driving my to distraction. One, they want to hold the deposit for a year after I stop using the electricity and have paid in full. And, when I call to report power outage and give them my home phone number they always say they have accessed multiple accounts and start by giving the first five digits of the address so I can Identify the correct one. I tried all along to make it clear that there is no connection between this house and that house and they send the bill to that house without asking. Also, every time I call in, I give them my Cell phone number so they can reach me, but they call the house phone anyway and then complain that I never answer it.
Thank you for the help. I followed your link and then found the file and downloaded it. Told it to run run run. I would have no idea where to save it or what to do with it after I did. So, it went through the flying files cartoon and then the install and then it went away. I looked in All Programs and found it and tried to open it under the assumption I should tell it something, like when to shut down, (power flicker, power out for a minute, or what ever) The file Is paconsole.jar and Windows bitches that it can't open it. Wants to know what program to use or should it go on line and hunt for one. Beats me. I don't even know if I SHOULD open it let alone how. This thing is supposed to make my life easier/better. Not so much. Got to go try to earn a living now, be back after a while.
John McGaw
If the file extension is .JAR then it requires that the Java Runtime Environment be installed before it can do anything. This is so common that I suppose the company assumed every computer would already have it. This is sloppy thinking but finding a computer anywhere without JRE is a true rarity nowadays.
Thanks again John, I downloaded Java and the program went to work. I am just barely able to operate Wood Central let alone know what jar is or about Java runtime. Amazing to me.
John McGaw
I'm glad I was able to help a bit and I hope the software and UPS work out for you when the inevitable next power failure comes.
Thanks again and>>>>
My power has gone out so much recently that I just call them every morning and schedule the repair. Just so I will be first in line when it goes out....
