Creating a ramp on one side of the edge
North of the Border
I need to make a 3" or 4" in dia. and 2" thick cam for a toy project that looks like this (the edge thickness would be bigger):
http://www.leevalley.com/en/wood/page.aspx?cat=1,43411,43417&p=32215
How would you make the ramp like that (say from 2" down to 1/4") along the edge on a router table or handheld or a sander or any typical shop tool (TS, etc.)?
Thanks in advance for any suggestions (a picture or two would be greatly appreciated if the technique is going to be complicated) or idea.
Re: Creating a ramp on one side of the edge
Moses Yoder
Moses Yoder
I would mark it out with a piece of good masking tape then go to it with a mallet and a 3/4" chisel. It really would take taht long, jigging up to do it safely with a power tool would take a long time. Worth it if you are doing hundreds but not for just a couple. If I was doing a hundred of them I would set up a striaght bit in a router and a jig to do it but it would be a fairly complex jig.
I'd consider hand tools - handsaw and chisel, specifically, followed by sanding.
Cut your stock out (getting it to circular), along with a piece the same diameter but a little longer, on which you can screw* the piece you're working (imagine your final piece as an extension of a cylinder**). Lay out the ramp by marking out the highest and lowest point, then wrap a strip of typing paper or card stock (card stock's probably better, if you've got any the right size; a cereal box would work, if you can get a dead straight line on it) around the stock and trace a layout line along it. Similarly lay out a line on top of the stock for the width of the rabbet/ramp. Cut down at various points around the circle with a small backsaw to remove most of the waste, then clean and refine the ramp with a sharp chisel, paying attention to grain direction of course. A little scraping or sanding should bring the final refinement.
Power tools have their place, but one-time things that don't register against a fence of some kind are often more easily done by hand.
*I'm assuming you'll have a pivot point in the center of the cam. Some sandpaper or, even better, drywall sanding screen (rough on both sides) trapped between the stock being worked and the cylinder to which it's screwed should hold it still.
**If you cut flat spots on the cylinder, below the area you want to retain to make your layout easier, you can clamp it in a vise.
Being a wood turner I would first turn the overall shape using a square waste block. then I would mount my router on my table that fits in the banjo. Tilt the waste block so the piece you turned is now at the right angle to make the cam. Feed the router in, lock it in place and then rotate the piece by hand from the hight point until you reach the step. You would have to clean up the corners if necessary by hand because the router would leave a round stop cut.
Steve Strickland
Steve Strickland
I might try mounting it on a circular backer that had a 360 degree template pasted on. This backer is mounted on a bolt with 16 threads per inch so that it can turn freely without also turning the bolt.
Rotate the backer and then turn the bolt to feed the work into the cutter. A stationary router would work nicely. If you're going to feed 1.75" through 360 degrees at 16 tpi then you would turn the bolt 1 full turn for each 12.85 degrees you rotate. Break it down into 1/4 turn for each 4.2 degrees and the result should be pretty easy to sand smooth.
I think the jig would be fairly straightforward to build.
To get really fancy tilt the jig to match the slope so that the router bit makes smaller steps.
Thanks all for your inputs!
North of the Border
