THE WOODRAT IS BACK!
Does anyone sell a driver for slotted wood screws
Bill Tindall
I am so annoyed I could bite, well, screws! I own a dozen or more screw drivers and none fit a #4 slotted screw. Actually, none of them ideally fit any slotted wood screw. And, the way they are sold one has no clue what they might fit if one is ordered. To wit, a 3/16" screw driver!?! What size screw does a 3/16 driver fit! Now if one needs to fit a #2 Phillips one can buy a #2 driver, ditto for square drives. But need a driver for a #4 slotted.......you're screwed. To further the problem they are all tapered in at least one plane and likely two. Wood screws have straight sided slots, so why are the drivers tapered in width and thickness?
With tools being offered for every imaginable purpose it would seem that someone must sell a slotted wood screw driver. Why everyone doesn't is a mystery.
Re: Does anyone sell a driver for slotted wood screws
They Don't Sell Them Because...........
Dave's Not Here
Nobody under 70 would buy one.
Slots are only for removing...
Tom Dunlap
...is what my college roommate said :) Hammers are what are used to install them.Kidding of course.
Have you tried the bits that come in the 1/4" driver sets? they might not be perfect but at least there are several to choose from.
Jim DeLaney, Austintown, Ohio
Re: Does anyone sell a driver for slotted wood scr *LINK*
Try Brownells gunsmithing supply.
Brownell's
I would...
John in NM
And I'm 41 :D
'course I don't have a cell phone, smart phone, satellite dish, etc, etc...
Randy Johnson
What you need are hollow ground screwdrivers. The idea of the tip is that force is exerted at the bottom of the slot.
In addition to the Brownell�s link you might want to look at my personal favorites.
http://www.chapmanmfg.com/
The post above about no one under 70 wanting a straight bladed screwdriver illustrates the increasing difficulty in finding straight slotted screws. The simple truth is, that some projects require them.
I�ll never forget how mad a guy at the local gunshop got when I asked him why he had used phillips head screws on a Kentucky long rifle he had built.
FredD
Makita used to make slotted driver in different sizes which had a sleeve that kept the bit engaged without slipping out of the slot. I still have a couple of them.
Gunsmiths have excellent screw drivers thatclosely fit the screw and they are expensive.
FredD
Norm Knoxville
Bill, I feel your pain. Over the years I have ground and filed my drivers to mate with the slotted screw. Especially good on antique materials. Still have the set of Craftsman I bought when I left the service in 69, though they are somewhat shorter than they were then.
A luddite on the net..
Mark Nowicki
is it possible? :)
The closest I got is a Snap On model
Gary Smyth
SSD - 1410. It's not made for wood, but it has a long reach and serves its purpose with minor tweaking. Crown tools used to make wood handled "cabinet makers" drivers - maybe still do - in various sizes. I believe that they were hollow ground. I like the idea of gunsmith's drivers. I'm going to look into them. That idea never occured to me. Also, I'm sure you are aware that one technique is to do a pilot to depth then use same size steel wood screws for the first drive, and leave them a tad proud and in for a few days. When finishing up I remove them and put in brass or bronze for final look and there is barely any effort on the slot.
Gun smith secret revealed
Bill Tindall
Now I know why they can remove screws that I can't.......
Impossible!
John in NM
Really I think it's more pragmatism than any kind of Luddite sympathy in my case. The like of slotted screws comes from doing a bit of renovation - far easier to clean years worth of old paint out of those slots, hinges and electrical outlets always seem to have been painted over six times.
There's also something irrationally appealing to me about slotted screws, just like one type of wire nut over all the others. Go figure, we like what we like :D
The lack of cell phone for me is all pragmatic, just not worth the money to me.
I was going to suggest a Gunsmith's screwdriver. I don'to have one, but have heard good things about them. Somebody beat me to it.
I needed a really good slotted screw driver for about two screws, so I made one. I used a phillips that was worn out and ground the tip until nothing was left for the phillips part Then I clamped a bar across the haft so that I could turn it over and maintain a perfect 180 degree rotation. the cross bar was at ninety degree tot eh shaft. Laid in on the grinding wheel and ground one side. Flipped it over and ground the other. Kept tweaking it back and forth until I had the thickness I wanted and it was centered. I was my favorite screwdriver right up until I lost it.
more details
Bill Tindall
the bar thing might compensate for my lack of manual dexterity, but I don't understand the arrangement
Re: more details
Bill, I am trying to remember exactly. Years ago I made a tool rest for my WoodCraft grinder. Its a long horizontal bar of round stock that runs all the way across the front of the machine. This was somebodies idea of a universal tool rest. The rest of the system was a number of small homemade clamps you put onto the tool to help you keep it aligned. Some were nothing more than two pieces of wood maybe an inch by three inches that were sandwiched together with small bolts and wing nuts. You clamped you tool between them so that the tool was at ninety degrees to the clamp and then rested the tool on the round bar and used the clamp to keep it square to the bar and wheel and also to set the projection. The projection determined the contact with the wheel and by extending or retracting the tool you could get most any angle of contact you wanted. So you could sharpen a Chisel or a plane iron or the tip of a screwdriver. I used the contraption a little and still do once in a while, but I found my set up to be too flexible for any real precision. OTOH if you were gentle with it and touched the steel lightly to the wheel (a good idea) you could quite nicely sharpen things.
I could take a picture if you would like.
In your case, without having to build the space shuttle, you could probably use the same approach. Does your tool rest have a straight outer edge on it parallel to the wheel? Take two little sturdy pieces of wood and cut a rabbit in the edge. Bolt them together back to back. Install the soon to be new screw driver between them so that the shaft is perpendicular to the edge/rabbit and adjust the two blocks so they are parallel to each other. Then set the rabbet onto the edge of your tool rest and rock the blade of the screw driver onto the wheel. I suspect you will want to make the clamp blocks clamp onto the handle of the screwdriver to give you a long projection of the blade to give you a tangential approach to the wheel. That just mean the clamp bolts have to be a little longer. I could make this in less time than it took to describe it. The only real "trick" is to set the screwdriver into the clamp and tighten the bolts snugly but do not over tighten then and flex the clamp blocks. They (the rabbet) needs to be straight or the screw driver will rock and you end up with a oval point.
As complicated as this sounds, once you get the setup, you can do a beautiful job of sharpening a screw driver. I hate slotted screws as much as most, but a screw drive that really fits makes a huge difference. You only need an 1/8" of the business end to be "purty". If the screw drive you have is tapered, you can snub back the end to get to the thickness you need and then touch up the faces for a precision fit. I am not into tempering metal, but I suspect you could heat and quench Te tip and get it hard enough that it would break before it would round off.
A couple of questions. Does anyone know why slotted screw drivers have those "wings" or whatever the flared tip is called? I suspect they were put on there by the wooden plug industry so you would blame the screw driver for the poorly fitting plug and not the plug.
And how do you spell Rabbet for a wood worker?
got it
Bill Tindall
I have drill rod ordered, it is amazingly cheap. I give a knife maker tomatoes and he owes me one, so I have a means of heat treating the drill rod. Your trick will ensure success.
But.....why doesn't anyone but gun smith suppliers make a suitable screw driver and what is the purpose for the keystone shape, useless for the purpose at hand.
Looks like an opportunity for Lee Valley tools to make some.
Keystone
Flat bladed screwdrivers are drop-forged/stamped which, of course, spreads the metal shaft wider for the tip. Saves weight and metal as well because you can make a serviceable 3/8" tip from a 1/4" shaft blank. The wide part of the keystone makes the tip stronger and allows the point to be ground back to fit wider screws.
[Asked this same question of a pattern maker decades ago. Above is what he told me.]
kmealy
Lee Valley: http://www.leevalley.com/US/wood/page.aspx?p=56716&cat=1,43411,43417
They aren't bench quality
Gary Smyth
But HF makes a set called a security bit set. It has nine (9) sizes of hollow ground screw driver bits (lower section, (right) top row in pic), and more. The price is right -- $8 on sale, down from $10, for the whole set. You can get an additional 20% off on that item if you qualify. They're short, hex ends, and require your chuck. It will get you through until you find something better.
sounds reasonable
Bill Tindall
Much cheaper to forge than grind
bewildered
Bill Tindall
I copied the link you provided and it took me to the midst of some forum that was discussing these screw drivers.
Worked for me - into LV site catalog
Bill Howatt
My machinist
Nathan
I noticed that my machinist grinds his own drivers for slotted screws. He takes an ordinary screwdriver that is oversized for the screw he needs to drive (or remove) and grinds the tip to fit the slot on whatever screw it is he needs to deal with. As you say, the two planes are not parallel. But they are when he gets done grinding. He only grinds the very tip of the driver - just the depth of the slot plus a little bit more.
Of course, being a machinist he's very good at free-hand grinding. If I were to attempt such a thing, I'd probably use a diamond file.
One thing is sure: I've stripped many a slotted screw head in my time.
I agree with the poster who wrote they don't make these drivers because so few people would buy them. The production runs would be small and the retail price high. We live in an imperfect world.
Not too irrational
Nathan
I, too, am 41 and I don't think it's irrational to like slotted screws. From a purely visual standpoint, they look so much better (in a finished project) than any of the alternatives. Of course, in a woodworking project the best looking screw is no screw at all. But whenever you need a countersunk screw, a slotted one will look better.
I have salvaged a bunch of old tapered screws (never used) of various sizes. I'd like to use them someday. I've looked around, but have not yet found reasonably priced tapered drill bits for making the tapered pilot holes.
Of course, back in the day, awls were used for this purpose. Before I get into this any further, I should probably move over to the hand tools forum!
Taper point drills for wood screws *LINK*
Nathan
Straying off-topic here, I did find a supplier for reasonably priced drills for making tapered pilot holes:
ICS Cutting Tools (no affiliation)
