Have a question? Ask Woody!
Glue Strength of Lacquer
Stuart Johnson
I've just finished some frame and panel cabinet doors and think I might have created a problem. After I made the panels I stained and finished them with a coat of lacquer sealer and two coats of lacquer. They fit tight with just a bit of movement. After assembling and gluing the doors I applied stain to the frame and then sprayed the same finish order as the panels. All is dry and they look good but the lacquer has in effect glued the panels and frame together. Will the normal wood movement be enough to break the bond and allow the panel to expand and contract? If not I might be able to run a utility knife along the edge but with the way I twitch I'm sure I'll slip a bit from time to time.
Re: Glue Strength of Lacquer
I wouldn't use a utility knife - try something finer.
I will tell you that I've had a panel split because it was restrained by a finish. The finish was not lacquer though.
FredD
If Lacquer could actually do that , there would be thousands of split panels.
I have made a few and not had that problem.
FredD
Moses Yoder
Moses Yoder
The stiles on our doors are molded, and the molding heads have a slight relief formed into them at the edge of the groove. Basically, the groove is about 1/32" wider into about 1/8" from the edge. That way stain goes in when they are stained, and the finish does not adhere to the panel to stile joint. On the other hand, I have finished a lot of doors and never had them split because the finish stuck the panel to the stiles.
