Pressure Treated versus Salt Treated
David Yoho
I haven't had a need to purchase or use treated lumber for years, so I'm out of touch with what's available and the terminology now. Recently a co-worker asked what the difference was between pressure treated and salt treated lumber. I told him I thought it was all the same but he said he had read something indicating there was a difference.
My question is - is there a difference and, if so, what is it?
Re: Pressure Treated versus Salt Treated
In the olden days, you treated lumber by pressure with poisonous salt solutions. They were the same thing. Nowadays you treat them with ACQ - which is "sort" of a salt solution.
The salt in the old days was often copper chromium arsenate. Other salts included sodium borate. The pressure was the important thing. You had the pressure vessels with the stainless racks. You put about 20-30 lbs of pressure on the vessel and let it soak for a while. It drove the solution right into the wood.
Phil Joines
I don't know about the chemistry but around here there is none rated for use below grade. The coloration at least doesn't penetrate to the center of 2x4s.
David, I am out of touch also and I need to come up o speed on this. The old stuff was CCA treated, I thought it was Chromated Copper Arsenate. The Arsenic part of it upset the EPOA and we went to ACQ. Alkaline Copper Quaternary Supposed to be much less harmful to humans and the environment. But, very corrosive and you must use superior fasteners. Really good ones like high grade stainless are wise. Now some of it is treated with a Borate. Nearly harmless, but water soluble and they have been trying to work out a way to make it stable enough to use in the weather. Works well where not exposed to rain, but I am not sure they have it perfected for wet environs. Don't know what the fastener requirements are and I doubt it is rate of soil contact. Time for some research. Find out what the treatment process is where you are shopping and check it out. As far as the Salt thing goes, I think it was to different names used interchangeably.
Re: Pressure Treated versus Salt Treated *LINK*
del schisler
here is one search from google a lot's more. I wood read this.
http://www.naturalhandyman.com/iip/infxtra/infpre.html
Michael Wilkins
I moved to the eastern part of North Carolina in 1994. For a long time I heard reference to 'salt treated' lumber, and thought that there was some kind of salt treatment that made the lumber resistant to rot, bugs, etc. I later found out that the salt reference came from the company that sold and made the treated lumber, Salt Lumber Company. So everyone around here calls the stuff 'salt treated'.
