Need help with plastic laminate/contact cement
Made a counter top yesterday that is about 27" by 72". Has a radius on one end. Applied the Formica Brand laminate with Weldwood Gel Contact Cement. Applied the contact cement with a small disposable roller. Slathered on a even but generous coat. I was skeptical about the Gel formula, but the local borg did not have any of the Original formula in Quarts. Router trimmed the edges. Rolled it with a J roller firmly and it seemed well adhered.
This morning I put it in my truck to take it to the house where it will live Along the way we stopped for about an hour and it sat in the sun. The can says it has high heat resistance. Basically the laminate turned loose and it was flapping in the breeze.
Any suggestions for a repair/recovery? This is a real bummer, I thought I had done a good job.
Re: Need help with plastic laminate/contact cement
George Colonel's Workshop-Havertown PA
Good Evening Barry,
Perhaps you can remove the plastic laminate completely and use a solvent to remove the adhesive from both the laminate and the substrate. I once had the same problem and used gasoline. I put my pipe away first. Don't know what the solvent is for the materials you used. I'd find out and give that a try first. Otherwise, get a big big BIG bandsaw and resaw the countertop, and generously coat a traditional adhesive on the upper surface of the bottom cutoff following smoothing. Then apply another coat to the replacement laminate.
Damn, I hate that when it happens! Try the solvent idea before buying new materials----or that BIG bandsaw.
George
Lacquer thinner will remove the laminate fairly easily. The problem is that if I remove it completely it will be nearly impossible to reinstall it because you have to have the laminate larger than the substrate. If it comes to that I will saw the substraight down a quarter inch in width and length. This just ticks me off. I talked to a friend who has been in the cabinet biz for forty years and he said the sun turned it loose. The heat cooks the glue and releases it. The label on the can says the glue reaches full strength in 7 days. Seems it would have been useful to explain it was subject to failure form being in the sun sooner than that. Should have wrapped it up, but who knew? Could have used a clue.
Jesper, Denmark
Jesper, Denmark
You have had good suggestions for repair/recovery. I cannot add to that.
Understanding what happened may help in future: The heating by the sun caused the solvent in the glue to outgas faster than the substrate would allow it to escape, so forming bubbles that lift the substrate. It does not matter if the solvent is water or some hydrocarbon.
Longer drying time between mating the two surfaces will help. I had the same problem with a laminate for a chart table on the boat - where the solvent was trapped between the plastic laminate and a dense substrate. The solution was to drill some holes in the substrate to allow the solvent to escape.
