Pressure treated wood
Dan Turner
Im working with pressure treated wood making a gate. Do I have to leave gaps so that the wood can expand and contract?
Re: Pressure treated wood
Most pressure treated wood is soaking wet and swollen when you buy it and the usual problem is it shrinks when it drys. Pressure treated wood that has been Kiln Dried After Treatment (KDAT) is available in some locations. So is Air Dried after Treatment (ADAT). My experience with the ADAT stuff is that it was drier than the wet stuff at the lumber yard, but not nearly as dry as any kiln dried lumber. It shrank after it was installed.
What I am saying is that if you are working with the wet stuff you should design significant shrinkage into your project.Once it drys/shrinks it will shrink and swell like any other wood (pine=a lot of shrinkage). Nothing about the treatment process will reduce or eliminate this characteristic of the wood.
yes
Normally the stuff is somewhere between 40 and 100% water (chemicals), and it needs to dry to EMC. There is, however, SYP that is No. 1., double kiln dried, but you won't find it at the Borg, and it's usually special order at best.
If I work "treated", I buy it a month ahead of time, wrap it in visqueen with a fan and a light, and fahgedaboudit for a while. I take 5% more than I'll need and then take the pretzels back for credit. :D
