bugs in wood
bugs in wood
bugs in wood
Jerome Mills
I recently cut up a cedar tree in a friends yard and brought the wood home. The next day I observed mounds of saw dust all along where the wood lay. Looking at the bark I noticed a large number of tiny holes and then was able to see an insect aroung the pile.
Does any one know what this is and is there a way to get rid of them ?
Re: bugs in wood
Re: bugs in wood
Doug Ridley
A hammer works pretty well.
Re: bugs in wood
Dale Lenz
Re: bugs in wood
Dale Lenz
I'm assuming the cedar tree was dead when you cut it (?). Again guess, what you are seeing are secondary bugs, bugs go after the wood after the tree has died. In most cases, the bugs will leave when the wood is dried down to woodworking moisture content.
Re: bugs in wood
Clint Searl
Re: bugs in wood
Clint Searl
On Eastern Red Cedars cut live, the bark must be stripped immediately to keep the buggies from making trails under the bark in the cambium. Don't know about other kinds of cedar. Strip the bark and put the log in the sun with lots of air.
Clint
Re: bugs in wood
Dale Lenz
Re: bugs in wood
Dale Lenz
The log in the sun this time of year will surely crack the wood easily. With all due respect, I'd saw the log up , peel the bark or have the mill trim the bark off and sticker stack it with a cover outdoors, let the wind intially dry the wood down to 12-15%, then stick it again inside your shop to bring the MC further down.
Re: bugs in wood
McKinneyMike
Re: bugs in wood
McKinneyMike
Sounds like powder post beetles. I would treat it with TimBor or an equivalent type product and keep it a long ways from my lumber stash. Powder post beetles can be active in dried lumber unless it has been kiln dried properly. They will not go into the heartwood, but they will eat into sapwood, which is what you are seeing.
Not a bug that any lumber man wants anywhere around their quality lumber. Be careful with it as these bugs are not to be taken lightly. Personally I would burn the wood unless it is to be kiln dried as cheap wood that destroys a lot of good wood is not something that I would even remotely consider smart personally. een too many infestations because care was not taken.
Re: bugs in wood
2  nd that don't get it near other good wood
del schisler
eather get it kill dryed or treet it. I know that you would like to keep that wood. But don't get it near other better wood tell it is free of maybe pp beatles.
