O.T. Google Maps
Stuart Johnson
Is there anyway in Google Maps or one of the other online map sites like Yahoo that allow you to plot your own course?
O.T. Google Maps
Stuart Johnson
Re: O.T. Google Maps
Henry Higginbotham
Mapquest will show you what it thinks is the best route between two points, and then let you grab the "path" and pull it through waypoints that suit you better, changing its written instructions along the way. Is that the sort of thing you're looking for?
YES
Craig Daymon
Google maps has allowed you, for several years now, to click on a point on the plotted map and move it to a new course. It will recalculate the mileage and all the trip information for you.
Put in your starting and ending locations and it will plot the default path. To alter the course, just click a point on the path and drag it to the detour you want to take.
Re: O.T. Google Maps.. thanks both work
Stuart Johnson
Re: O.T. Google Maps-???print full page maps
Tom Dunlap
Another question...
I like using Google Maps for lots of reasons.
Is there a way of making the map larger than the 'box' on the main page? I'd like to have a larger map without all of the other froo froo around the edges when I print out the map.
Or...once a route is selected is is possible to print just the map to a full page?
Henry Higginbotham
This may not be exactly what you want, but it works for a lot of things. I use it often to print maps without all the stuff I don't want around the edges.
Download FastStone Capture (I think 5.3 may be the last free version) and use the capture window (third icon) to drag a box around just the part you want. You can then save that screen capture, print it, doodle on it, etc.
Like this:
Tom Dunlap
Thanks...I'll play with that tomorrow
