OT - Soil pH tester? Or other means of tick ctrl?
We've got chiggers and ticks in the yard.
I want to try controlling them by judicious applications of sulfur. This would lower the pH of the soil and supposedly repel or kill the ticks and chiggers.
Naturally, I would need to determine the soil pH first. Can anyone recommend a tester? My hydrangeas are blue - so I know I have fairly basic soil.
Re: OT - Soil pH tester? Or other means of tick ctrl?
John Veerkamp
Get chickens or Guineas.
Frought with risk and adverse consequences
Bill Tindall
Screwing up your soil chemistry to avoid spraying a pesticide is not a trade I would lightly consider. I bought a farm for next to nothing because nothing would grow on it. There weren't even birds on the place. It was as the neighbors said, "dead". Soil pH was acidic. Added 3 ton /acre lime and after a year all was well. You are proposing to reverse this experience.
The sulfur will take quite some time to acidify. First some has to dissolve and it doesn't dissolve very fast. Then what dissolves has to oxidize to sulfuric acid, again a slow process. The chances of vastly overshooting a target seems near certain and you will have the only yard in the neighborhood that only grows moss.
To answer the question you asked, there isn't a cheap, accurate means of determining pH. The procedure is to weigh 50 grams of dry soil to 50 mL of distilled water. Stir and allow to settle. Measure pH of liquid layer with calibrated pH electrode. There are even more complicated tests depending on your soil chemistry. The local ag or extension office will do it for $5. Look under county government offices in phone book.
FredD
We have both and they keep the Ticks down to a low roar and Sevin judiciously applied to dogs does the rest.
FredD
Re: Frought with risk and adverse consequences
Doug Ridley
There is a cheap accurate way to test for ph. Take several soil samples over your yard and take them to your local County Extension agent. It used to be free but like everything else there may now be a small cgarge.
Doug
Living In A Lyme Hot Spot
I'll pass along my method.
I have my yard and 20' into the woods sprayed with a pyrethrum preparation 3 times a year [late April, June, late September] to correspond to the the three stages of tick life cycles; nymph, adult, and fertile. Ticks are easy to kill and Pyrethrum is a low toxicity "natural" insecticide which breaks down with no residue or migration.
Sevin OTOH will knock down a number of beneficial bugs and can create a "bloom" of other, very harmful insects because the food chain is disrupted. That's why Sevin has been removed from most use.
Everyone in my family has had Lyme; my wife and I twice. Since I began this control program, we've been all clear.
BTW, a neighbor tried the "Ginney" method. They quickly had the neighborhood up in arms over the birds' racket, and had to ship their flock out.
Re: Living In A Lyme Hot Spot
R. Payne
Is it Pyrethrum or is it Pyrethrin (or even Permethrin)? Both are available.
Pyrethrin is a synthetic chemical bases on pyrethrum (an extract of the chrysanthemum) and is quite a bit more toxic than pyrethrum. And it is toxic to most or all insects, and it is toxic to fish. There is some evidence it may be harmful to cats. And there is evidence that it is harmful to mammals (including us) if inhaled.
And even though pyrethrum is natural that doesn't equate to low-toxicity but it may be better than lyme disease.
ron
