Finishes for shelving... Conversion varnish?
Now that I've got the wood and it is sitting in the shop "equilibrating" for a week while I go off to VA for a while.
The shelving will be used to store "boxes" of music. The boxes hold individual pieces of music (about 30-40 pieces) of a couple of sets of music. The boxes can weigh 5-10 lbs.
I'll be realistic. Most of the time the boxes will sit on the shelves. Once in a while, the choir director will get a box down and select pieces for use. So basically, there isn't a lot of repeated wear - just occasional wear. Dust will collect - so there is that problem.
I was thinking with the amount of shelving (three sets of shelves with 7 moveable shelves per set) that I would spray as opposed to anything else.
I was thinking of a 2 part conversion varnish as opposed to anything else. We have a Sherwin-Williams store, so I was thinking about using one of their products. I'll only need a gallon or so.
I was going to go with a vinyl sealer then a top coat of conversion varnish.
I can spray and have the finishing done in a single morning.
I'm asking now so I can make sure the product will be on hand when I need it.
Thoughts??
