Shelving - solid hardwood or plywood??
Cost of materials:
Red oak (12" width and greater) - $2.40/board foot for 4/4 nominal
Red oak plywood - $55/sheet
So the plywood is running ~ $1.72/board foot (nominal).
The shelves will be used to hold the music "boxes", hymnals and whatnot for the choir. I estimate the weight of one of the music storage boxes to be on the order of 10 lbs. They are about 11 1/2" deep x 7 1/4" high x 6" wide or so. So figure on at least 20 lbs per foot.
The Sagulator calculations say plywood would work nicely - but southern red oak would also work fine.
So the question - solid wood or not?
If I do plywood, I'd have to put an edging strip on the shelves. I'd either have to put a face frame on the uprights and outer shelves or put an edging strip.
I'm thinking that the labor would probably be more for the plywood. The lumber is S2S and straight line ripped. I'm thinking that I would need on the order of 140 board feet (possibly less) for the needed lumber. I'd need at least 4 sheets of plywood and edging material if I went the plywood route.
I'm really leaning towards solid wood. I'd have 1/4" plywood backing.
Thoughts??
TIA
