recommendation for shop blower/vac? *LINK*
DizD
My craftsman impeller disc torqued off the shaft for second time and I don't know if I want to replace the part again. Doing a search found a Vacmaster, supposed to be the latest and greatest - all for less than $100. Anyone have experience with this unit or other combo unit you like?
http://www.vacmaster.com
Re: recommendation for shop blower/vac? *LINK*
Galen Vetterick
I wanted to replace my old screaming Sear vac with something I could stand to run while sanding. I found very few vacs that gave good air flow and static pressure ratings and none much on decibel ratings.
I ended up with a Rigid 14 gal Model WD14500 11amp. meaningless 6 peak Hp and listed 168 cu ft/min. Also got an optional muffler that I cannot by ear tell the differance in sound. The hose is a little stiff but I had lots of old hose.
It does very well connected to a hood I have at the lathe and can watch sanding dust go down the line. It actually pulls through an Oneida Dust Deputy and I use the option paper bag and not the pleated filter it came with.
It'not hard on the ears at all running but I have no way to measure. It seems to do well picking up shavings off the floor.
This was a $99 Home Depot machine so not a high end unit but does what I wanted.
Thanks for the input on noise level.
DizD
I was thinking about looking at Ridgid. The big name quiet vacuums don't have blowers and I clean my shop with the blower more than the vacuum.
