Evaluation of a Titanium Nitride coated plane blad
Bill Tindall
Titanium Nitride TiN) coatings (that yellow coating seen on tooling) are used to provide improved wear to wood bit tooling, for example CNC router bits. It may provide the same benefit to a plane blade, which remains to be tested.
Ron Hock, Hock Tools, provided a coated A2 steel blade for a No. 5 Stanley plane. The blade had been sharpened and the back polished before coating. We do not believe this blade is the best test of the concept of a coated blade but it is a blade in hand and some testing will proceed. In addition we hope to have coated a blade that may provide a better test of concept. I will post on this site results with the Hock blade as we get them. You all are invited to suggest experiments to do on this blade. As seen in the photograph, the blade looks elegant.
Experiment 1 Corrosion resistance
TiN provides a corrosion resistant barrier on steel. In this experiment a spot of water was placed on the coated and an uncoated blade. After a day one can see the orange rust spot on the uncoated blade. One can also see the spot where the water was applied to the coated blade but only a mineral deposit from the hard water is visible. There is no corrosion.
Next photomicrographs of the coated edge will be made, planing tests performed and then photomicrographs made to determine how the blade is wearing. The planing will be repeated after the bevel is sharpened to see how the sharpened bevel performs. (sharpening will remove the coating from the bevel but not the back. In a bevel up plane configuration there will likely be some self-sharpening of the edge. We don't know what to expect on the bevel down Stanley plane configuration.
Steve Elliot and Bill Tindall
