We value your privacy.
Anyone out there use the small air guns, airbrushes, etc. I'm looking for a spray gun that will do "touch-up" type work on damaged finishes and small to medium size projects. What are the best brands out there for lacquer,water based finishes,shellac, varnishes and stains? What has been your results with what you have used and any learning curve involved. I'm looking for something simple but effective.
Since the 1960's my choice in airbrushes has been the Paasche line. They are simple and kept clean will do excellent spraying. The are so easy to use even a Caveman can do it,
For a larger job, though, I've been using an HLVP "touch-up" gun from Harbor Freight. It's a gravity feed with a 125 cc (about 5 oz) cup. Usually priced around $40.00, it does a very nice job with the shellacs and water-based finishes that I mostly use. I actually like it a lot better than the much more expensive Graco touch-up gun I used to use.
Prior to retirement I was an Engineer at Mallory Controls, we did a lot of manufacturing of Automotive products (switches - controls etc.). I had several lines that required spraying white area's of light pipes etc. I tried several airbrushes and determined Paasche was by far the best. They are very durable, easy to adjust, clean, and easy to teach operators to use. These are all made in Chicago, IL and tips and replacement parts are also quickly available. These can be ran off a large compressor (with low pressure regulator, or can be used with a small "air brush compressor.
Several years ago I needed a small gun for touch-ups and small pieces, especially turnings. I did some research and settled on the CA Tech. mini gun at the link. This is a superb mini, and the kit comes with two top cups, and three cap and needle combinations. I've sprayed shellac, lacquer, oil urethanes, dye toner, and waterbornes. I also use the optional on-gun regulator for very precise control of the air in the gun.
I only spray conventional and only lacquer. For small and detail work I use a Sata gravity feed. For anything bigger than a cigar box I use a DeVilbiss one quart gravity feed or an old DeVilbiss syphon feed with an eight ounce cup. A regulator at the gun is advisable.
I worked leather for a hobby for years and the Paasche was always considered the top of Air brush equiment, but the Binks was every good and a whole lot cheaper and you could mount small jars of dye to them whereas the Paasche took cmall open cups.
The units I purchased did use glass "cups". I did try Binks, but in the industrial usage we found the Paasche to be easier to adjust, and clogged less. In one application we used a clear base with a mixture of white paint that when sprayed on the tip of a light pipe, became the indicator light for the Cadillac headlight control knob. Controlling the thickness of the coating was critical as the light had to show through, while the indicator had to appear solid white in daylight. The operation was a 16 hour/day, 5 day week so reliability and ease of use was critical. These unit were relatively inexpensive (for an industrial application) so replacement wasn't an issue, but downtime and problems were major. The Paasche did last for several weeks in our application, usually replaced due to damage caused by mishandling or failure to clean properly. I'm not saying Binks wouldn't work fine in most hobbyist - but I know Paasche will work in all.
