Freeing a rusty drill chuck....
I have an old Dewalt drill with a keyless 3/8" chuck. I let my son's friend drive the work truck home one night. He decided it was not necessary to put the tools inside the cab because he lives in a crime free neighborhood. Apparently he did not realize somebody's sprinkler system came on in the night and put about an inch of water into the bucket that had the drill sitting in it, nose down. No one mentioned it to me for several days. The chuck is rusted and stuck. I oiled it with air tool oil but to no avail. I now have it soaking in brake fluid. Is there any chance I will be successful? Anyone know how to remove the chuck from a Dewalt drill?
Re: Freeing a rusty drill chuck....
Ouch!
Pretty well all chucks remove from drills the same way: remove the left-hand-thread screw accessible at the bottom of the center of the chuck...when the chuck is all the way open; for keyless chucks, close...the chuck on an L-shaped Allen wrench, as large as possible (3/8" for a 3/8" chuck, etc.), and strike sharp blows on the outer end of the wrench's leg with a hammer in the direction that will cause the right-hand-threaded chuck to unscrew.
But that's when the chuck will operate. How you do it when the chuck's frozen, I'm not sure. Is it one of those chucks with the plastic sleeves on the outside? If so, and if you can get to and remove the screw inside the chuck first, you might be able to put Vise-Grips on the sleeve closest to the body of the drill and hit the Vise-Grips with a hammer to loosen the chuck.
I'm afraid a lot of frustration awaits you. Can your son's friend afford to buy you a new drill?
Thanks Bill, Sadly no....
I am flipping houses trying to develop some income for my retirement. Lets just say that I have not done as well preparing for retirement as I should have. So, I am scrambling. At the same time, my son has fallen on hard times, so I have him working for me earning some income until he gets a real job. His buddy is worse.
The drill was utilitarian. In fact, I hate it. Its old and decrepit, but it still worked. We called it "Old Yeller" and I used it sanding at the lathe in hopes of allowing it to die an honorable death. OTOH I will have to spend a few hard earned bucks on a new one so I am not too happy to see this one go.
Lets hear it for Brake Fluid....
I want to thank who ever posted the tip of using brake fluid to free up things seized by rust. I have used it twice and it worked both times. Once was on a large "bolt" in a screw jack (tele-column) I found under the house we are working on. It had been lying in the dirt for years and was a mass of rust. Soaked it over night, turned it with a pipe wrench, wire brushed the thread and oiled it. You can turn it with you fingers. Last night I put the tip of the drill chuck into the brake fluid and this morning, I worked it loose and cleaned it and oiled it and it seems as good as new. So, Brake fluid works on rusty stuff. Now I am not sure I am happy I don't have to buy a new drill or sad I Get to keep working with this POS.
Thanks Again.
Re: Lets hear it for Brake Fluid....
Stuart Johnson
A while back there was a thread about using brake fluid mixed with something else usually found in a shop that was suppose to be great for fast rust removal or penetration. I did a search but didn't come up with anything. Does anyone else remember the thread?
Re: Use it carefully
Ralph Lipeles
Just me neat and careful when using brake fluid. It will lift paint and leave you with a mess.
Ralph Lipeles
And wear gloves; have good ventilation
There was a thread a while back that stated that one of the best penetrating lubricants was transmission fluid mixed with a solvent - as I recall mineral spirits. I have mixed up a batch of this and it did work well in my application. It seemed to work better than WD-40 and some other commercial penetrates that I use.
You May Have To Chuck It, Barry
Now, That Was A Lucky Brake, Barry
Stuart Johnson
Thanks Larry, I knew it was a couple common things.
I like that one George!
Galen Vetterick
Kneale Brownson
Acetone was the carrier for AT fluid.
Kneale Brownson
Re: Now, That Was A Lucky Brake, Barry
FredD
Your back to par Colonel , two zingers in thread, hoorah.
FredD
Did I use the wrong stuff?
Was I supposed to be using transmission fluid, not brake fluid?
Whatever I should have been using, brake fluid worked for me twice.
If it worked who cares?
Phil Joines
Marvel Mystery Oil ?
Don Orr
I sort of remember hearing many years ago that Marvel Mystery Oil was actually either automatic transmission or brake fluid. Anybody shed any light on this vagure recollection? It's good stuff. Not even sure if it's still available.
Re: Marvel Mystery Oil ?
Back in the 70's I had a Dodge Charger that had hydraulic lifters. (I am not a car guy and I may have just said my ramsama had reasole in its creazesin.) When It sot noisy and started to clatter I would add Marvel Mystery Oil tot eh oil and the gas tank and it would quiet down. I saw a can of it at an auto parts store recently and it was like a flashback. It worked for me. No idea what it really was.
