Mark 1 spray gun
Jim Shockey
I just picked up a mark 1 spray gun and was wondering if anybody could tell me a little about it. Can I shoot poly with it or not. Thank you, Jim
Mark 1 spray gun
Jim Shockey
Sorry
to answer a question with questions, but
1. Top cup, siphon feed bottom cup, pressure feed bottom cup?
2. Size tips?
3. Oil based or water based?
Re: Sorry
del schisler
here is what i found on the spray gun. I don't thank you will be able to spray poly with those nozzel size's. I spray lacquer all the time with a 2 mm size. Don't know about poly size nozzel. some one will chim in with more i am sure . Here is the speck's i found.
Nozzles Included (qty.) 2
Required CFM 4.5
Operating PSI 30 - 40
Air Inlet Size (in. NPT) 1/4
Nozzle Size (mm) 1.0, 1.5
Paint Cup Size (oz.) 4 1/4, 20 1/4
Paint Cup Material Plastic
Case Included Yes
Manufacturer Warranty 12 months parts / 12 months labor
Ship Weight 7.0 lbs
Item# 156409
Re: Size
Dell,
I've sprayed Mixwax oil-based gloss poly with a 1.5mm cap. You have to thin the product a bit (I used 25% b/v naptha) and 40 psi supplied to the gun with a wide fan. Material flowed out quite nicely.
I shoot WB poly often through a 1.4mm cap with no problem.
Thanks Mark for info Re: Size
del schisler
I jsut havent need to spray other than lacquer. I know some one would know. thanks del
Re: Thanks Mark for info Re: Size
Jim Shockey
Thanks everybody for the help on this gun. I can't even find out who makes the darn thing so I can't even get some different tips. thanks again for your help. Jim
Re: Size -PS
Remember that when you're spraying any waterborne, especially through a smaller (1.4/1.5 tip) that you MUST strain the finish just before using it. A standard painter's paper/mesh filter cone will do (rinse and reuse) to remove any lumps of thickened product that would clog your tip. While some finishes will do beautifully at true HVLP in the lower pressure ranges, heavier bodied fluids may need more air to properly atomize in an even cone. I always start a new batch by spraying a sheet of white copy paper with a single pass. I then hold the sheet up to back light and check the density of the finish across the surface.
Good Luck
