We value your privacy.
I just installed a new T&G floor for my screened porch. On the advice of the supplier I brushed an exterior deck sealer. It does not quite have the look I want. Can I now go over it with an outdoor satin varnish or poly? The sealer was applied 6 days ago and is dry to the touch and does not mark when walked on.
You want to avoid a varnish for an outdoor deck. Exterior varnish is not that durable because of its high oil content. And, most importantly, it is very slippery when it gets wet. It is dangerous to use finishes like that for wet locations.
Of course, any type of poly varnish should be avoided in exterior applications. Urethanes are rapidly attacked by the UV in sunlight and will quickly become cloudy, then crack and peel. Finishes containing UV protecturants are only marginally longer lasting.
Use a finish intended for decks for the best results. Go to your local library and take a look at the June issue of Consumer Reports. They report on their on-going long term testing of interior, exterior and deck finishes.
It's also important to know how much, if any, of the floor surface gets direct sunlight as this will effect the coating unevenly between sunny and shaded areas.
I used Sherwin-Williams clear water based deck sealer.
The porch is 10 X 21. The 10 side is on the south with no overhang or shade. The 21 is on the west with a 1 FT overhang and tree shade in the afternoon from about 3:00 on.
I know that paint is traditional on screened porches. This one was painted for 34 years. I just replaced the floor with thermally modified T&G (Pure Wood brand). I stained it with a reddish brown stain and really like the color. The deck sealer leaves a matte finish that shows dust from every foot fall. They do wipe up but a PITA. My thinking is that something with more gloss like a satin would not show prints so readily.
If I understand you, you have the stain sealed under a flat finish WB sealer. That being the case, for a quasi-interior surface I'd consider recoating with a good WB floor finish like semi-gloss Bona Mega. I would first lightly buff the floor with a steel wool pad for a better bond, then apply one coat with a roller or squeegee. The sun is going to fade your stain over time, but you knew that, right?
I should mention, John, that putting a more "durable" gloss finish on the floor will make things more difficult when it comes time to refinish. Deck stains and sealers are generally short term products that will give you only a couple of years' use (if you're lucky) before breaking down and needing to be redone. Putting something like the Bona on may require you to resand the floor as you would on other interior wood floors.
I know that the finish will require more maintenance than paint , but the boss is making some definite input. Thanks to all for the input. I'll make a visit to the blue box later today to see what they have.
