We value your privacy.
When spraying lacquer how long do you wait between coats? The directions say two hours between coats but I would assume they mean for a brushed on application. I am thinning 50/50 so i would assume it would dry quicker but this is the first time I've tried this.
out of a can??? or HVLP ? IF out of hvlp and sprying a sanding sealer? It would be dry enough in 1/2hr. sand and than spray a top coat . I wait a couple hrs and spray another coat. I only put 2 coat's on. If you put more on you have a chance of cracking in a few month's. I spray lacquer for lot's of yrs and this is my set up. I use HVLP sprayer with a 2 mm nozel and 35 lbs of air. I don't thin that much 50 50 . I may thin like 10 percent. the more you thin the more you waste the thiner. And don't get a good coat of ingredients just more thinner and you have to more coat's on. I use M.L.CAMPBEL only i don't use the box stuff at all. Not good enough for me my 2 cents
Your thinning to much , many Lacquers like the Gem Pre-Cat I use require no thinning at all
In California I used a very good locally made Lacquer by the name of Crown and it recommended 20% reduction ,so a five gallon can really was six gallons after the introduction of a gallon of thinner.
I spray with a Graco airless rig and after I apply one coat of a Vinyl Sanding Sealer , and sanding it the next day, I cross hatch four coats of Lacquer . This would not take more then a hour at most on a large set of Kitchen cabinets.
I do not sand any more and the finish comes off the gun very acceptable. This is the procedure I use for Kitchen cabinets .
For Furniture I will rub it out with Mequiars rubbing compound available in Auto Parts stores.
It is my view based on spraying thousands of gallons of Lacquer that the quality of the coating is directly related to how good of a tip you use and Graco has a double orifice stacked tip made especially for Lacquer, coupled with their Pro Silver Gun model that produces a finish on wood that looks as slick as sheet metal finished.
That is way too much to thin. In fact there is no reason to thin at all unless you have having some problem that would be mitigated by thinning. Recoat when it feels dry and doesn't highly smell of evaporating solvent.
Sand when it is hard enough to no load up the sand paper.
Some specfics on what I am useing. I have an Earlex 5500 sprayer that I will be useing. Useing Deft lacquer, satin finish, with Deft sanding sealer. I have both a 2.0 and 1.5 needle. Since this is the first time spraying, I usually brush, I am going to do some test strips but I am really looking for starting point for the mix ratio and recoating time. I had thought I would do sanding sealer then three coats of lacquer with no sanding in between the coats of lacquer and then rub out. I am open to a different method if you think I am way off with my method. I am spraying a library stand and need it to look good.
Unless I need to retard for because it is too hot of too humid I don't thin the lacquer I use. The solvent system for the particular lacquer is formulated to avoid many of the features of applying lacquer (runs, orange peel etc) and changing the solvent system with thinner could lead to it being more prone to runs. I once had some "high solids" that was thinned 30% but it stated on the label that it was to be thinned.
Practice spraying water on a piece of cardboard. Then practice spraying lacquer on something flat. You want full wet coats applied with overlapping passes.
Once you have become practiced at spraying you will wonder why you never did it before.
As Bill suggests, practice on cardboard or scrap wood, learn to hold the gun the same distance through the spray stroke , always cross hatch , that is a vertical stroke for one coat and a horizontal the next pass.
I would suggest spraying the cardboard standing vertical rather then flat to get a feel of how much you can lay on without runs or sags.
Your thoughts about a Sanding Sealer then Lacquer with no sanding of the Lacquer works for me. But to get there from here requires a lot of practice and actual on the project spraying.
One or at the most two coats of Sealer is all that is required,more then that will give your top coat a soft finish that is weak.
I can't comment on your equipment for spraying, but follow the directions on the can for thinning or not.
