OT Microwave timer question
I have a Sharp Carousel 1200 watt microwave. The timer has gone wacky. At first it was displaying an extra "1" in the display so that 1:30 looked like 1:130. Last night the power went off for a while and now the time displays gibberish. Just a bunch of short vertical and horizontal hyphens. It still works and seems to keep up with the time but the display is nonsense.
Is there a reboot or other fix? Or is the end of the unit?
Re: OT Microwave timer question
John McGaw
It is highly likely that you can buy a new electronic control/display module but not knowing the details I can't check. I've had good luck obtaining appliance parts from www.repairclinic.com
Bill Howatt
A power-cycling on-off-on with say 30 seconds minimum at the off stage is typically what will reset the electronics.
I looked at the Repair Clinic site for Sharp control boards and they are tend to be $100+ but you would have to check your exact model.
Given the cost of regular microwave ovens these days I don't think it makes sense to replace it unless the unit has special features or is relatively new with lots of life (hopefully) remaining in the other components.
Bill
And I would add ...
Mike Farinella
A microwave oven is the only appliance I would consider buying an extended warranty on.
Mark Nowicki
A shot of electronic cleaner/degreaser on the contacts has cured a similar condition on our microvawe.
Mark
Re: And I would add ...
Mark Nowicki
How much would you pay for an extended warranty for a $100 appliance?
Dependent on the age (if less than 2 years old) I might work on it by removing the control panel and spraying it with alcohol. To me it sounds like you may have a bad solder joint or bad IC that feeds the display. Many people don't know this but the power of a microwave reduces with age. The magnetron weakens with age just like the old Vacuum tubes used in TVs and Radios. Since a new Microwave costs from $50 to $150, it is seldom worth having one repaired or even repairing it yourself considering the price and issues finding repair parts. If I get 3 years out of a MW oven I consider it a throwaway item. Mine is reaching that age - it still works ok, but is getting noisier and the touchpad is getting harder to push. I have also noticed the pint is wearing through on the inside of the cabinet. So I will start looking for a sale on a new one. The plant I retired from produced the old mechanical (rotating knob timers with a bell) MW timers, then we produced the newer digital timers (until the products went overseas). I was the Manufacturing Engineer on these lines.
