Why aren't carbide blades coated with TiN
Bill Tindall
Some others and myself have been investigating the coating of woodworking blades to see if cutting edges can be made more wear resistant by coating with titanium nitride (TiN) or similar coating. The process has gotten cheap and it is used extensively for tooling, even things like molding machine cutters and CNC router bits. A natural application would seem to be saw blades. In theory the blades would stay sharp longer because TiN is greatly more wear resistant than carbide and the wear edge is partially self sharpening.
There is another coating used on woodworking cutters and other stuff, Chromium Nitride. It leaves a shiny chrome colored coating on the tool. Certain Freud blades have a shiny chrome look. Could they have this coating?
Re: Why aren't carbide blades coated with TiN
FredD
Most of the saw blade manufacturers have doing something similar for awhile now.
Vermont American Tool Model # 27831
THIN KERF - TI CARBIDE TIPPED
``TITANIUM 10X''
5/8" ROUND ARBOR
Carded
Dia.Ins.10
Unit: 1 per card
Unit Weight: 1.8600 lbs
UPC Code: 045325278314
Back to Top
Moses Yoder
Moses Yoder
Wouldn't the advantage of this be lost after the first sharpening?
Clint Searl
Re: Why aren't carbide blades coated with TiN *LINK*
Clint Searl
I have a combination blade with tips of a composition material, Cermet, made up of ceramic and TiN and/or TiC particles that I got from Carbide Processors. I haven't used it enough to determine if it's longer lasting than TungstenCarbide, but their tests suggest that it is.
Clint
Cermet
If I visualize this properly the advantage would not be lost. On a bowl gouge, the inside of the flute is coated with TiN. You sharpen the end of the piece of steel exposing a new edge of the coating only a few molecules thick. So, On a saw blade you would coat the surfaces you do not grind away.
FredD
The example of a Vermont -American, has Carbide teeth alloyed with Titanium Boron . so the teeth have the benefits of the alloy in them , rather then a thin coating on them.
FredD
advantages? would not be lost on sharpening
Bill Tindall
I had a detailed conversation a technical rep at a coating factory. The following is what he emailed to me......
"TiN has been used in wood cutting/shaving/chipping blades. It tends to
offer low drag and buildup.
The TiN has a very tight grain structure compared to the steel. Thus it
can actually be honed to a sharper edge. This characteristic has been
used in razors.
The blade can be resharpened many times by grinding only the bevel side,
keeping the TiN coating on the other side of the edge. Many blade
applications have followed this design.
The cutting edge will last longer and the wear on the back surface will
be reduced.
The other benefit of this approach is that you create a self-sharpening
edge design. This is because the cutting edge will now consist of one
side being TiN and the other side being steel. The wear will be greater
on the steel side than the TiN side. The result is that as the steel
wears slightly and the TiN edge remains, the edge remains sharp. Of
course, this cannot last forever, and the blades will need resharpening.
But, the edge should remain sharper longer than currently experienced."
Re: advantages? would not be lost on sharpening
Ron Jones
I noticed that the tech rep always mentioned steel, not carbide. Is it possible that the carbide is enough harder than the TIN that the coating would not be worthwhile?
craigd
craigd
Coatings on carbide tooling is pretty common for metal working. I've used it machining stainless and cast iron and it is really nice.
TiN is much harder than carbide
Bill Tindall
