We value your privacy.
A friend asked that I make a simple cross. It is simple except he wants the arms connected with 45 degree "arrows," for lack of a better term. Each arm comes to a point in the center.
I can use biscuits or a spline, but I am concerned I may not achieve co-planer...is that the right term; everything flat.
There may be a pattern of half-lap joints that would help keep it flat, but I have not figured out exactly what that would be.
If I understand correctly you want four arms to meet at a center point so the arms are perpendicular, each arm has a point at one end where they meet. The other end is trimmed to proportion.
It sounds as if it�s a simple length jig with stop blocks and an accurate chop saw. Where is it going? Is it a gift for someone other than your friend? How large? Indoors or out? Finished or painted? It may not need joinery. Glue may be sufficient If that isn�t enough you could assemble it, glue it up, and then dowel the arms in, even pocket hole afterwards. Are both sides to be seen? You might be able to support the arms with a stopped rabbet and metal strip screwed flush into the back. Unless you want this to be an exercise for you in joinery make it simply and have your friend tell you more of his thoughts and application .
The cross is for my friend's wife and is to be hung on an interior wall. It is to have a natural, clear finish, not paint. My goal is a nice cross, not an exercise in joinery.
I am uncertain whether glue will hold since these are nearly butt joints.
Bob, You could make it by lamination. What I mean is make a cross, half-lapped at the junction, of material that is one-half the final thickness. Then machine the "show" part to the specifications of the recipient, and glue those in place on top of the half-lapped part. This will allow the cross to have the look he wants on the front, and have the strength it will need, due to the hidden piece holding it all together. The overall cross will be substantial enough to last a very long time. Good luck with it!
Make the cross with the mitered joint in the center as desired. Then cut a slice through the pointed part of each only to the depth of the points and parallel to the face. Then cut a spline square out of thin but sturdy plywood or even the stock the cross is made of. You could turn the grain at a forty five in the square spline. This would be easier than making and laminating two crosses, but not as strong. It would not have a lamination showing and should be strong enough. Once assembled it would be completely concealed. (wish I could draw)
Thought the same thing, Barry, plus, sandwich the cross lightly during glue up with two pieces of plywood to keep both axis of cross coplanar. Cut out viewing windows in plywood to see what you are doing when clamping and to keep the glue off the plywood.
