OT? Did I screw up?
Gary Camp, Bend Oregon
My local lumber yard just delivered enough pre-primed SPF to put batts and a belly band on my house and shop, prior to painting. I guess I know what I'm doing for the next few days.
glc
OT? Did I screw up?
glc
Oh Mamma !
steve mackay
I need a translation.....
What is SPF? What's a belly band? I think I am too far east of you to understand.
Re: I need a translation.....
Steve Schoene
SPF is easy--spruce pine fir ie. the way most framing lumber is sold if it isn't DF.
Belly band is more often called band board. It's a horizontal trim board, often between floors, or between materials. Remember, just like at all transitions it needs to be flashed, and if it stands proud of the siding below, it should also have a drip notch on the bottom.
Barry, SPF is non-structural grouping, of Spruce/Pine/and/or True Fir (as opposed to Douglas Fir)generally sold pre-primed with one face rough. The Belly Band, at least in my case, is a SPF 2X10 with an angled sill on the top. The belly bands are mostly at the bottom of the siding, at my house, it will be raised about a foot to cover a joint in the siding caused by new footings when we put the house on a new foundation. We are using 1X3 batts above the belly band and 1X4 batts below. We will be covering the grooves in t-111. This look is being used alot on the recently built "Modern" Craftsman Style homes in our area. I kind of chuckle when builders talk about upgrading or "modernizing" the look of a house by going back in time. You don't live to far East, I just live to far West, it is however still 150 miles as the crow flys to the Pacific Ocean (200 or so by road). I work with a younger guy from upstate New York and sometimes you think we wern't speaking the same language. Hope this made sense
glc
Draw me a load of sand.....
I think what you call a Belly band is what I would call a Frieze Board. A band board here is the piece of lumber that is perpendicular to the floor joists sitting on the sill and nailed to the ends of the joists. The most common thing I can think of called batts here would be insulation that comes in pieces as opposed to the shredded loose fill kind. I Knew what SPF was except I was kind of confused by the Batts thing. The batts you mention would be called battens here as in Board and Batten siding.
I think Steve's mention of a drip groove is amazing. A detail often overlooked here. I made a rose arbor that was 12 feet in diameter and it had a "finial" that was forty inches tall. There was a 12" diameter ring in it and I turned a drip groove in the bottom of it. The painter did not grasp the concept and caulked it full and smoothed it out very nicely. Oh well, you can only try.
I hear that in upper New York state you don't haul a load of sand, you draw it.
Thanks for 'splainin'.
Lazy Westerners
'round here ya never hear Board and Batten,just Board and Batt, thats 2 whole letters saved. Also, again 'round here, a Frieze board is up just below the rafter tails. ah New York, lots of different terms.
glc
