Crick in the neck Question...
About a week ago I woke up with a crick in my neck. Its sore up the left side. It persists. Any advice? Do these go away on their own? Can't afford a Doc right now.
Chiropractor Is good For this
Bart Goldberg
Re: Crick in the neck Question...
Jason Roehl in Lafayette, IN
Ibuprofen and ice.
Another one that can help is to lay on your back on a hard surface with a rolled up towel under your neck. The diameter of the rolled up towel should be enough to make this position uncomfortable, but try to relax anyway.
Jason
It's called getting older
Stuart Johnson
The aches and pains that would have sent me to the doctor are now just signs that I'm still here and moving.
Agree...
John in NM
Ibuprofen and ice, works wonders
Ice should be limited to 20 minutes or so every couple hours. Wrap the ice pack in an old t-shirt or something to avoid frost bite.
Take Two Aspirin and Call Me in The Morning
Ken Oakley-Sunny St. Cloud, Fla
Sleeping hard, eh?
Kneale Brownson
I find alternating heat and cold helps some. Apply to areas above and below the painful spot too.
Best way to avoid this is to include a neck stretch in your daily exercise/stretch routine.
I twist my neck as far as I can to the right for 10-15 seconds and then slowly reverse to the left for another 10-15 seconds repeatedly and almost never have a stiff neck anymore. Used to be a regular issue for me 30 years ago when I was in my 40s.
Right pillow height, & Stretching
Keith Newton----Little Rock, Arkansas
The cause was probably either too high, or too low pillow. Make sure that when you lay on your side, that you neck stays straight.
Now that you have it, ibuprofen, and stretching. One simple stretch that I use, is to just bend over at the waist, and hang. When my muscles are stiff, I may do good to touch my knees, but as all the muscles up my back side slowly relax, I can make it all the way down to the floor. Once I reach the floor, I continue to hold another minute, just letting the head hang, with no muscle tension.
I can't take the burning in the back of my legs if I try to keep my knees straight, so I have to bend mine to get through this. When you straighten back up, raise your arms straight up, then take turns reaching as high as you can reach, bending a little to each side in the back. After a few of those, bring your arms down and take three deep breaths, letting them out slowly.
You can also lean over the arm of a sofa or other armchair, and hang to stretch the side muscles, gently pushing the had a little with the opposite hand. Once again just hang there for a little while.
Finally, it is easy to massage your own neck. The neck has lots of trigger points, that can be excruciating when they are pressed, but don't let that stop you from finding them and pressing on them. As you probe down into the muscles with the finger tips, then move the pressure toward the end, where muscle connect to bone. Where the muscle become tenon, you will likely find some of those zingers.
Manipulating trigger points can be like putting your hand in a vice and tightening it as much as you can stand. It hurts like hell, but when you let it out, the hurting quits. Only, with this, the crick will be gone.
If it hurts to stretch, you need to stretch more, not quit. Do the bend and hang 2 to 4 times a day, only takes a couple of minutes each time, and you can massage your neck while you drive down the road.
Cut back sitting in front of this screen so much
Yonak
