cabinet door design question
Jay Lombardo
I am looking for suggestions to design a door for a medicine chest I am building for family member. I already built the carcass and frame, and she went to salvage yard and bought old stained glass window (sash and all). Got the glass out without breaking anything and now am a little stumped on how to incorporate a 16 wide by 20 long stained glass into a door that needs to be 36 3/4 long by 21 wide. any suggestions would be greatly appreciated. Door is going to be overlay.
Thanks,
Jay
Re: cabinet door design question
You use 3" rails and stiles for the frame then top your stained glass section with a mullion and section of new glass [even a stained glass section you buy or make] to take/make up the top 9".
There, wasn't that easy? :D :D
[psst. did that once. I feel your pain]
What is the question?
Is it that you don't want 8" rails and 3" stiles? If so, Mark's idea of adding a complementary glass panel of some sort is a possibility. I'm sure there are other filler options depending on your taste. Or, are you looking for ways to construct a door with 8" rails and 3" stiles? If it is a traditional interior, maybe you want conventional-looking cope-and-stick rails and stiles. Or, for a more modern look you could miter them together with long asymmetric miters. Or go off the deep end and make natural-edged stiles and rails. Most of this decision is about aesthetics and what works with the rest of the decor.
Moses Yoder
Moses Yoder
I would put another panel at the top, decorative wood of some sort, either curly or spalted or something. I would decorate the wide stiles somehow, maybe a light inlay on dark wood. I would make the top & bottom rail the same width as the stiles and maybe do an inlay all the way around.
Yonak
Gee, this is the funnest part of woodworking. Do you want others to have your fun for you ? To me, imagining woodworking projects is like dreaming.
Joseph Mulherin
Jay, with any project it is a very good idea to put down what you are thinking of ...on paper in drawings so you and you customer can see what they want and maybe incorporate any changes.... before construction.
