We value your privacy.
Table front with a 32" by 4 1/2" apron. Drawer in the middle that is going to be 18" or so wide. It is under the edge of the table so it really isn't going to show much. Drawer opening is going to be 18 x 3" or so.
Cut a hole or piece? I was planning on rabbeting the edges about 1/4" on each side.
I usually piece them. Actually rip that apron about a 1/4" wider than the opposite one and then mark it with diagonal chalk marks to help reassemble it. Then I rip the drawer piece out middle, Cut the drawer opening out of the rip, and then reassemble the apron with the opening centered in it. Doing it this way you can get pretty good grain match and the joints can be nearly invisible. Allow enough width for jointing the edges of the strips and centerpiece. If you allow a little extra length you can side slip the pieces to get better grain match. A quarter sawn or straight grained piece for the apron may work best. Also, with a little forethought you might be able to use the cutout as the drawer front.
We always cut a hole in the apron for end tables, with a CNC router. You could make a plywood jig to use with you router and a guide bushing, but you have to get a separate piece for the front. If you oversize the apron enough and cut it apart like Barry says you could use the cutout for the drawer front. I think cutting a hole in would be faster plus you don't have the glue joints to deal with, but it depends on your own objectives.
John Townsend made drawers in small tables by cutting a hole. He could then use the cut out piece for the drawer front because he added a cockbead attached to the rail to take up space left by the cutting. The cockbead also hides small tool marks on inside of the cut out where they are relatively hard to remove. On the drawer front, it can be brought to size and have any tool marks from the cutting process by a few swipes with a hand plane.
