What finishes to spray with HVLP system?
I've picked up an unused HVLP spray system (Rockler).
What would be some reasonable finishes to use with it? I was thinking some of the "water borne" finishes, but I'm amenable to anything else.
TIA
TIA
Re: What finishes to spray with HVLP system?
Jesse Cloud
HLVP can spray most anything. You may need to buy different needles for lacquer or paint. I've sprayed lacquer (solvent and waterborn), shellac, and oil based paint.
anything.....
Bill Tindall
I have sprayed anything that can be brushed with conventional spray- varnish, lacquer, conversion varnish, alkyd paint, shellac, etc.
The viscosity of the water based finishes doesn't rapidly build as the solvent evaporates, so runs are more a risk than with solvent based finishes that are polymer solutions.
Most Anything, But
Remember that HLVP was developed to primarily deal with waterborne finishes. If you're working with a turbine unit (basically a vacuum cleaner motor and fans) you can run into problems with solvent finishes (shellac and lacquer) because the turbine uses the air to cool its motor so the longer it runs the more heat is generated. This means that the air supply will warm up (some to the point where you'll need gloves to hold the hot gun). This plays havoc with solvent finishes as the solvent flashes off before the finish makes it to the surface. I started with a Fuji turbine, but moved to an air compressor-driven "conversion" gun with pressure pot because of the heat issue.
Most of what I do is waterborne and I truly prefer HVLP for that. I also do shellac as a sealer, and for that I'll use a touch of pure turps as a retarder to get a better flow-out.
Thanks for the reponses, all.
I'm going to try some Polycrylic or something I don't mind using in the shop.
Re: Thanks for the reponses, all.
mdclor
Whatever you spray, please wear a mask with the proper filters. Nothing that is sprayed is good for your lungs.
