We value your privacy.
1. Use a plumber's pipe cutter as for copper. Does fine although there will be a slight burr on the inside rim that files off easily.
2. Use copper pipe instead of EMT. Reason is the steel will rust and look ugly whereas the copper will patine to a very nice brown and/or green. The difference in sound between the two metals is slight in the sizes you're working with. You can "temper up" the copper for a higher pitch sound by heating the cut pipe sections very hot to the point of blushing and then letting them air cool slowly. This will also form some fire scale on the surface that you can either remove and keep for effect.
I've always used a hacksaw, but I haven't had to worry about dead straight ends.
If you don't have a stationary disc sander, as Alan recommends (a good idea, by the way), you might take a tubing cutter, use it to score the EMT for a clean square end mark, hacksaw just on the waste side of that score, then file back to the line. Don't have a tubing cutter? Take a piece of typing paper, wrap it around the EMT with the ends aligned, and use a sharpie to draw a line.
The burrs can be removed with the shank of a screwdriver - it's not terribly high-temper metal. Or you could use a rattail file.
Have you considered copper pipe? If you talk sweet to a local plumber, you might be able to get some at scrap prices - they always wind up with short lengths. Granted, copper's scrap price these days is pretty steep. But copper oxidizes to a really nice color, while EMT will eventually rust. If you use copper, you can use a tubing cutter, not a terribly expensive tool, to do all the cutting, and the ends will be subtly rounded inward from the pressure of the cutter wheel; you just need to deburr the inside then.
Anything I want precise and repeatable I always mark, cut long, then grind/sand down to my mark. After I'm happy with the first one I repeat but match the rest to the first, not a mark.
It's best to do this on a flame-proof surface. I use an old piece of lab counter material, but a piece of natural stone will do as well, but concrete will spall and pop and steel will tend to contaminate and discolor the hot copper surface. Keep your torch moving back and forth along the length. As the copper gets hot you will see it start to change to a lighter color under the flame. That is the blush. When you get an even response along the length, you're done. You can also selectively temper and color the copper by spot heating the metal. Spot heating takes a hotter torch, however, because copper's high conductivity will bleed the heat away from any one point.
You do want to get good at finishing to length, by the way, because you'll find it helpful when tuning the chimes to be able to remove just a smidge. Not that you need Carnegie-Hall-quality pitch, but it is nice to avoid dissonance. Unless, of course, you're making a wind chime as a birthday present for your Goth* teenage daughter, in which case you might qualify as a cool dad if you present chimes that sound like a car crash.
*Or whatever the modern equivalent of Goth is; our sons exited the teenage years 15 years ago, and I'm sure the terminology has moved on, although I'm equally sure that shocking Mom and Dad is still part of it.
TRYING to shock Mom or Dad is, was, and always will be "part of it" and a large part of it at that. Mom and Dad need to act properly shocked in order to let the condition run its course. Pull the "No son/daughter of mine . ." routine and you're just begging to get it in spades.
When used for electrical runs, EMT, whether cut by hacksaw or tuning cutter, should be deburred on its inside rim to prevent its slicing into cable and insulation jacketing. A tubing cutter will also produce a very slight crimp in the conduit, reducing its ID a bit. This can be restored with a reamer or mandrel or even a #2 morse taper tool from a lathe.
I have a nice sounding set made out of anodized aluminum tubing. The tubes are about 1 and 1/2 inches in diameter, with about a 1/8 inch wall. These could even be cut with a power miter saw with a carbide wood cutting blade, tho it makes a bit of a mess in your shop to have all those aluminum chips coming off the saw. The anodized aluminum looks like new after 4 years outdoors, year round.
I've used it for closet hanger rod, hand rail, and balusters and used leftovers for wind chimes. It cuts easily and accurately with a plumbers tubing cutter. Here's a chime I made about ten years ago out of stuff on hand; the tone is light and sweet. If you don't want it to rust just spray it with Rustoleum.
...they really do want Mom and Dad to set and maintain limits - at least mostly. Our one son tested our limits in some creative ways (can you spell "burning carpet in the bedroom?" You can sure smell it!), and was hanging with kids who weren't drawing him in directions he wasn't comfortable with, but couldn't admit to not liking.
One of the kids in that crowd, Jody, had a single mom* who basically set no limits on her at all. It became clear, as I watched her behavior, that Jody wanted, desperately, someone to tell her what was right and wrong and set some limits for her. We were a leetle busy trying to pull our son back from the brink, but I did try to say things whenever I talked with her.
We were really grateful when we were able to get our son away from that bunch, but I've wondered ever since if Jody found the parent figure she needed, or was able to reach down into herself and find that parent within her. She was a good kid (not something I can say about others in that group); just lost.
Talking about this reminds me all over again how much of raising kids is thinking about what to do a lot, and then following your best instincts; and trying again when the first attempt fails (and again...and again...).
*No judgments on moms here - there are plenty of similar dads, just fewer of them are single and holding custody.
Tom - I used to cut EMT for a living as an electrical contractor. For your purpose, you can use just about anything to cut it. If you are going to do a lot of it, I would get a power bandsaw and equip it with a fine tooth blade. If just a few, use a good hacksaw with a 32 tooth blade. There is a coating inside the tube that will help keep corrosion under control, so don't overheat it if you can avoid it.
Once you get it cut, you can remove the burr with a file. If you are doing a bunch of them, you can get a deburring tool like the one at the link below. It is quick to use and leaves a clean edge.
