Wine Rack
Wine Rack
Wine Rack
Hal
The LOML wants me to build a wine rack to set on a shelf in the pantry. I sort of know what a wine rack looks like but when I try to draw one out I get bogged down in the joinery. It must be relatively simple, but I can't get my mind around it. Can someone lead me to a plan(s) for a small wine rack or describe the joinery to me? Will much appreciate any help. TIA. Hal
Re: Wine Rack
Clint Searl
Re: Wine Rack
Clint Searl
I had that problem, too, so I switched to the kind that comes in cardboard boxes.
Clint
Re: Wine Rack
Re: Wine Rack
mdclor
More info is needed to provide options. What are the dimensions that you want to use? Do you want it to be squarish cubbyholes or diagonal openings? How many bottles will the existing shelf support? Will you store reds, whites or both (reds generally are narrower, but longer bottles)? Have you seen a picture of a design you like that you can post?
Re: Wine Rack
Re: Wine Rack
John Veerkamp
Simplest design. two pieces of wood(ply will do) for front and back. Cut holes for bottom of bottles in one. Smaller holes in the other for the necks. Join front and back like a box. the depth to accomodate wine bottles. Your choice of joinery: Dovetails, miter, butt. etc. Make to the width you need.
Re: Wine Rack
Uh Oh
Clint's doing the Thunderbird kegger frig-packs!
Re: Wine Rack
Here's a couple of versions
Gary Smyth
Called a riddling rack. Used for preparing bubbly. This antique is for sale on Etsy for over $800
Another version might be to stack terra cotta drain tile cylinders or in this case hex in a 4 x 4 (or whatever) arrangement and frame them in wood. Slide the bottles inside the tiles.
Re: Wine Rack
Re: Crude Wine Rack
Ray Carson - Lawrenceville, NJ
Hal,
This is really crude but I built one like this out of construction lumber. I'm sure scaling the parts down it would work just fine too.
Ray
Re: Wine Rack
Crude Wine Rack???
Lee Schierer McKean, PA
Is that something like crude oil?? A less refined wine? Sorry :D
Lee
Re: Wine Rack
Re: Crude Wine
Usually comes in cardboard boxes :D :D
Re: Wine Rack
Crude wine is
Gary Smyth
impolite, and brazzen. It is among the rudest of all beverages..
Re: Wine Rack
Often Served
with Crow, rare, feathers on. :D
Re: Wine Rack
Re: Wine Rack
mdclor
Wine bottles are of varying shapes and sizes. Therefore, drill holes of about 3.5 or 4 inches in diameter in your choice or material (needs to be only 1/4 to 3/8 inch thick depending on the span) for the back rails and about 1.5 inches in diameter for the front rails. Then rip these down the center so that each piece makes 2 rails. Rout stopped mortices in your stiles to accommodate the rails. Join front and back stiles using M&T or half lap or whatever joint you prefer. The front and back rails should be about 12-13 inches apart. Finish with a bottle of champagne to celebrate! :D
HTH,
Merle
Re: Wine Rack
Re: Crude Wine Rack???
Ray Carson, Lawrenceville, NJ
Lee,
I'm laughing, you just can't see me. Hey, the wine in our house doesn't last that long. I wasn't going to spend $$$$ on fancy woodworking that sits in a dark corner in the basement.
Ray
p.s. LOML and I call it "coping punch"
Re: Wine Rack
I like that Gary. LMAO !!
Re: Wine Rack
Re: Crude Wine Rack
My google sketchup is rusty.
Re: Wine Rack
Re: Wine Rack
Brian A
This may be a bit large for your counter but it works for me.
Brian
Re: Wine Rack
Re: Wine Rack
Brian A
OOps missed the URL
Re: Wine Rack
Re: Wine Rack
Brian A
Another view
Re: Wine Rack
Re: Wine Rack
Hal
Thanks all. Some good ideas and good humor. I sort of like the cardboard idea, but LOML is less than enthusiastic. Brian, I should be able to take yours and scale it down to make it work quite well. Thanks again to all. Hal
Re: Wine Rack
Easy one. PVC
Jennifer Indy.USA
I saw one in a catalog once that was made from PVC pipe. I just Googled PVC wine rack and found these. It would be quick and easy and you could really dress it up with some nice wood. If it's just going to sit in the pantry and not be a visual piece something like these might be just the thing.
Jen
http://www.wineintro.com/products/racks/pvcrack/winerack.html
http://www.custommade.com/wine-design-wine-rack-made-from-reclaimed-lumber-a/by/halaproducts
http://www.marthastewart.com/333157/turn-hardware-pipes-into-a-modern-wine-r
Re: Wine Rack
Thanks, Easy enough for my level of ambition!
Bill Howatt
Re: Wine Rack
Recycled PVC???? I ahve just about the lowest...
Squeem factor of anyone here, but Recycled PVC as a wine rack??? :( 4" PVC is POO Pipe in this neck of the woods. I don't drink much wine, but I don't want ANY that has been stored in a RECYCLED POO PIPE. ICK!
Re: Wine Rack
Re: Recycled PVC???? I ahve just about the lowest.
Jennifer Indy.USA
Barry I'm thinking that using "recycled poo pipe" might be just about as gross as you could get. Around here 4" PVC pipe is sold fresh at Lowes and Home Depot.
Jen
Re: Wine Rack
Re: Recycled PVC???? I have just about the lowest.
I actually liked some of the designs and I like PVC for this application and would use NEW PVC without hesitation, but I read the post twice and it said the pipe was recycled. Perhaps they have carried this recycling thing a bit too far.
