Possible OT - Shelving in the Parish hall attic?
Our new Parish hall is a Morton building. Wisely, the designers made the majority of the attic not easily accessible (nothing accumulates stuff more than a church).
At the end of the Parish hall, we have closets extending across the width of the building. There is access to the area above these closets via folding stairs.
Anyway - the studs on the building are run horizontally rather than vertically. It would be nice to have shelving in this area so we don't get piles of junk. I don't want to have to go into production mode and make lots of shelving if I have other alternatives.
The wall spacing is about 7' high or so by 8' deep x 50' long. I was thinking Closet Maid. I'm willing to listen to other suggestions including building/making shelves. I figure it would cost $1300 for four shelves running across the full length for Closet Maid (16" deep). Decent plywood (3/4" "cabinet" plywood) is running about $30 around here. So it would run $180 or so for the plywood, $60 for the paint and whatever else was needed for plywood shelving (say $400 for 2 x 4s). It would take me (and a couple of helpers) a week or so. I could have the Closet Maid done in one day.
So - what is a reasonable, inexpensive design that would work in this place? I can make shelf bases with 2 x 4s (or 2 x 2s) and have plywood on top of them. I can lag the shelves into uprights (with or without notches). I can screw each 8' section into the next section.
Should I go with Closet Maid (or equivalent) or build?
Re: Possible OT - Shelving in the Parish hall attic?
Re: Shelving
With the weight that is likely to accumulate, placed there by folks who don't consider things like "total load" etm., I'd never go with the Closet Maid stuff. It's too light for other than a residential closet and the fixings have a tendency to break [think of one of more shelves coming off the wall like a zipper BTDT].
Build it with posts every 4' to prevent sag in the warm attic. Speaking of warm, since you mention closets, make sure there's air circulation or you'll be cooking whatever's on those shelves and use K-D 2x unless you want "pretzel studs" and undulating shelves.
Clint Searl
Clint Searl
You might first consider commercial shelving. It's modular, portable, easy to install, and will carry the weight of a legion of sinners. Here's a couple I used; one 12" deep and the other 19" deep.
Clint
I'm with Clint.
Gary Smyth
Put out the word that you're looking for commercial stand alone shelving SHOW A PICTURE. I'm betting that there is a warehouse out there that has some to spare. Check Craigs list and even the paper notices of companies struggling. Spread the word but be PICKY because if you aren't you will only be cleaning house for someone who wants to get rid of his/her (often damaged)eyesore. You dont need much, but if you can find the right kind and enough of it, write the giver a letter for the donation, and spend the money on sandblasting, paint, and perhaps drywall or lumber sides and a face frame. Maybe this is the time for that electrostatic paint sprayer (appliances, file cabinets, yard equipment, etc.). If you are considering closet maid, doors are not in this budget so get the innards squared away first and make the shelves solid and smooth not some wire mesh. These won't go away for almost forever so get something that can be anchored to a wall, overloaded and people will stand on safely. You know it will happen.
Works for me.  I'll see what I can get for  $
I could do these in a modular fashion.
