OT - GFI replacement issues
Ray Carson, Lawrenceville, NJ
Hello all,
I need some electrical help from my WC family. Due to my error both GFI oulets in my pool circuit shorted out and needed replacing. Unknowingly, the Little Giant 505300 pump I was using had some frayed, exposed wires at the point of entry on the pump. After several attempts at at resetting the GFI outlets, nothing would work. It was at this point I realized the pump was defective. With the circuit turned off, both (exterior) outlets were rewired exactly as before. On these receptacles there's a samll green indicator light. One indicator light works and one doesn't. Both receptacles work fine and trip on "test" and also with my GFI plug in tester. I suspect two things could be wrong. One: Bad receptacle. Two: Possible issues with the sequence in wiring. I add the second reason because in the receptacle box there are directions on wiring before the the circuit is turned or something. I'm not clear on what they mean. I've read it 4 times now and it doesn't make sense. So..........any thoughts on why the light isn't going on? Should I just take it back to Home Cheapo and try another one? From my description, is my circuit safe even though there is no indicator light?
Thanks everyone for looking.
Ray
