Mortising curves, can your machine do this
Louie Lovas
Louie Lovas
Hi all, just thought I would share something interesting ...
I got this project recently to repair an old rocking chair, was a family heirloom dating from 1938 (clearly stamped on the seat bottom). One part that was broken was the lower seatback rail. It had a series of mortises for the back slates that followed the curve of the rail.
Rather than chop by hand, I used my drill press mortising attachment and held the workpiece in a cross-slide vise. The kind that moves front/back and laterally. Allowed my to easily cut a set of mortises following the curve. Did that first, then cut the curved faces (front and back on bandsaw radius jig).
If you're contemplating a mortising machine vs. a drill press attachment this may help you decide. Not sure how you would do this on a mortiser? The cross slide vise was a big help but takes a lot of table space, something a mortiser does not have.
Also, here's a link to pics of curved rail off band saw
http://flinthillfurniture.com/images/misc/ChairRailCuts.jpg
Re: Mortising curves, can your machine do this
It looks to me like your mortises followed the curve, with each successive one being angled in relation to its neighbor. Don't cross-slide vises move in an X-Y - right angle - mode? How did you dial in the angles?
A worthy discussion, though - I'm not criticizing, but asking.
Louie Lovas
Louie Lovas
You are correct I can fine-tune the X-Y position using the cross-slide vise.
In my case, the rail had 5 mortise. One is centered. The other 4 are mirrors of each other in pairs on each side of the center mortise. The vise (which is attached to a plywood base) is clamped parallel to the drill press table.
As I made each successive chisel stroke... it was parallel, along the lateral (Y-axis) movement, combined with slight readjusting along the other coordinate (X-axis) so the mortise cut along a line that would be parallel to the rail's curve.
I had the chisel turned at a slight angle so it's front/back were parallel to what eventually would be the sides of the rail (following the curve). Thus the final result was a 1" straight mortise whose sides were parallel to the curved front/back of the rail.
Sounds a heck of a lots more complicated than it was... really :)
Nothin tuit...
John in NM
I'd make a mating curved piece to attach to the mortiser's fence and just go from there. Each mortise is the same distance from the edge, so you just need a jig to hold the curved piece steady (got to cut the curve before the mortises in this case, but you can use the offcuts for the fence pieces). Saw lots of parts like that made in a shop for which I used to work.
I agree
Bill Tindall
A drill press is a multitasker that doesn't cost much different than a bench top mortiser. I too have a cross vice for these occasions.
Not intentionally
Neal in San Jose
LOL. Actually, I'd probably do something similar to what John from NM suggested. Saw out the part then use the off-cut to jig the work in place.
Yeah, With My Help
With a bench-top (JBM-5 sans cross-slide) I'd lay it out as you have, but then cut the convex (back) curve and use that against a 2-point fence to index the curve to the mortiser chisel. Did this very thing on a curved-back mission rocker. With two cuts for each mortice, it would need a touch of clean-up on the slight peak. Admittedly, having cut the outside curve first, I was risking a blow-out, but used several strokes with the chisel to minimize stress.
Nice job, by the way. Post a pic of the finished piece?
charlie belden
Yes - AFTER the curved part's been cut -with a Festool DOMINO.
Ralph Lipeles
The only problem I see with what you did is that the bandsawing goes across grain and ends up weakening the piece. When I have had to make pieces like you made I found it easier to just cut the mortises, steam the piece and clamp it between a pair of cuals for a few days.
Ralph
