Floor leveling compound Questions
I repairing the floor in the house I bought to flip. One piece of flooring failed in the kitchen. Its about 4 X 8' with one long side and one short side against adjacent flooring. The other two sides are in the corner and don't matter as much. It appears the Underlayment was 3/8" wafer board or OSB and there was vinyl over it. The kitchen sink leaked and ruined the underlayment and subfloor. The subfloor was 3/4" T&G and I have replaced it. Now I want to replace the underlayment. It appears 7/16" OSB will do the job and the extra 1/16 will compensate for the adjacent vinyl. The plan is to fill in the void and then cover the entire floor with another layer of 1/4" plywood underlayment.
So, what I am concerned about is the ragged edges of the patch before the 1/4 stuff goes over it. I don't want it to telegraph through the top layer. What cane I use as a skim coat to smooth out the transition? The vinyl is torn and ragged around the perimeter. Don't want to remove it. Might have asbestos. The wafer board layer is really stuck down and would be a bear to get out. What can I skim coat with that won't crumble and crunch.
Re: Floor leveling compound Questions
FredD
FixAll
FredD
