spindle repair results
DizD
I decided to repair this chair spindle rather than remake the whole piece. The top 4" or so was missing so I turned a replacement and cut a scarf joint and used slow set epoxy to put it together. Here it is with new wood installed.
And here after being wiped with stain and one coat of shellac. Final finish to be NC laquer. (Repair is second from right)
Re: spindle repair results
Nice job
I don't think casual observers will ever notice, and if they do, they've got way too much time on their hands.
Good work.
Ellis Walentine, Host
Dale Lenz
You're hired!
Dale Lenz
How did you cut the scarf joint?
Slick ! (I still can't see it !)
steve mackay
Well Done!
Either skill or blind luck
DizD
I'm still not sure which. I made a wood sided miter box a little wider than the spindle and cut what I thought was a suitable angle in the sides. I cut the broken end first after wedging the spindle to keep it from rolling. Then I held the new piece over the spindle end until it looked like it lined up, made a mark then cut it with the same miter saw kerf. I was amazed at the fit. Also waxed the inside of the box and used it to hold the pieces while the epoxy set.
Dale Penkala
Looks exellent! Great job!
Dale
Mid-Michigan
