How would you build a box with glass top
DizD
which would never need to be opened? I was thinking about building a mitered frame around glass like it was a wood panel and then fastening the frame to the box body. Then thought that if the glass should be broken, there would be no way to replace it without rebuilding the frame. Should this be a concern? The boxes will be used to display a sand collection. While writing this just thought maybe a candlebox type lid would be better, where glass would slide in from the end.
Re: How would you build a box with glass top
My take on this
I never build glass into a frame so it can't be replaced. That's just my principle and you may be willing to take your chances. If this glass is to be flush with the top of the frame, just cut a rabbet that fits the glass closely and set the glass in it. If it needs to be secured so it won't fall out if the box is upset, tack it in with a thin fillet of Lexel in the corner of the rabbet.
If the glass is to be recessed, consider rabbeting the glass opening from the underside and holding the glass in with removable strips of wood that are either pinned or screwed in place.
My 2�,
what is Lexel?
Bill Tindall
I certainly agree on always making glass replaceable.
Re: what is Lexel?
John Veerkamp
crystal clear Hi-tech sealant. Available wherever caulks are sold.
steve mackay
I did a "closed" shot glass case for BIL. The thought of the glass breaking never occured to me. Sure enough . . . ! After that, if they're "closed", I make sure I can get the glass out either by sliding out the side or removing the bottom of the box and going in that way.
Thanks for that
DizD
I'm a great believer in the old adage "Learn from the mistakes of others cause you won't live long enough to make them all yourself."
