We value your privacy.
Kinda sorta start'n to look like a tool chest now. This is just a dry fit. Still all scraps. And, this far along, it's STILL actualy square ! A first in my life. I'm begining to think mere mortals can do this stuff. Cut'n the bottom and back panels today. Think'n I'll finnish and give 'em the first sanding before instalation. Thoughts on that ?
That looks good. I look forward the finished picture as well. Insofar as sanding, I've found that as much as I can get done before things go together, the better. I would definitely sand the panels before they are in place. Depending on what finish and if you are going to have the panels floating, you might even want to put a finish coat on them before it all goes together so that if things swell/contract a little over the year you don't expose unfinished edges of the panels.
I dry fit the panels last night and was STUNNED that every single daddo (16 !) lined up on all four panels. I'm baffled and giddy. Hang around WC long enough and your bound to pick up some stuff by accident I guess. Makes you better looking too.
As to "floating" panels . . . I had been thinking how I was going to manage to get glue on all these edges and joints, get it together and clamped before I had a solid, cock-eyed mess sitting there. Why or why not would we glue in the panels ? Just expansion and contraction or are there more mysteries I haven't thought about ?
Seeing as no-one else has replied here is my .02 worth. The panels are left floating to avoid splitting them due to the inevitable shrinkage/expansion with humidity changes. Most panel door builders will leave approx 1/8" gap all around the panel to allow for expansion and some will use some sort of cushion in the grooves to prevent the panels from rattling. Lee Valley has some available, they're listed as 'Space Balls', others will use very thin strips of foam rubber or sill gasket material to cushion the panels. If you glue the panels into the frame without allowing for expansion you are almost guaranteed to wind up with split panels.
I never thought the movement could be all that much. But since this is a first and , I'm hope'n, forever we'll do 'er right . . . the FIRST time. Err and react or ask and avoid trouble. Thank you.
(should lower the stress level during assembly too ! )
