Have a question? Ask Woody!
Problem with Bosch 1613EVS Router
Ralph Lipeles
I purchased a Bosch 1613EVS routher at a tag sale today. But when I got it home I found that the router is stuck in the down position. I tried pulling the locking lever. It moves and feels like it is connected but the router does not release. I went to the Bosch website but the manual and parts list do not download. I appreciate any help or suggestions.
Thank you,
Ralph Lipeles
Re: Problem with Bosch 1613EVS Router
Ken Garlock, Collin County Texas
Good afternoon Ralph.
Go over to ereplacementparts.com. They have a parts explosion of your model router.
Good luck with a fix for your problem,
Ken
del schisler
i have the bosch 1613 router but not the plunge. I would take it to a repair place and let them look at it. their are not a lot of thing's in their to go wrong. I have a few other router's that have the plunge. I look at the http://www.ereplacementparts.com/bosch-1613evs-0601613734-plunge-router-parts-c-128_1119_1127.html and not much help their. good luck that is a good router.
Dave Paine
I have the 1613EVS plunge. The ereplacement.com parts diagram is very informative.
I think the #40 adjusting sleeve or #41 Locking piece may be stuck.
Looking at the diagram and my router, it feel like a lot of disasembly is needed to get to the inner workings of the plunge mechanism if you cannot free this.
The #57 compression spring is not very strong. My unit needs a little assist.
Try turning the unit upside down, pull back the #59 bellows and spray a penetration product like liquid wrench on the #40 adjusting sleeve. Let this sit for a while and then try a small clamp set to expand to add some force.
I hope this helps. Good luck.
The repair was a success.
Ralph Lipeles
I removed the 4 screws that hold the base assembly to the body. This was very tricky with the router stuck in the plunged doen position. There wasn't much room. I had to use a small right angle Phillips screwdriver and rotate it a fraction of a turn at a time for each of the 4 screws. THis then released the base and exposed the internal rods. One was badly rusted. It needed penetrating oil, 320 paper and gentle tapping with a rubber faced hammer. I finally got it apart and did more cleaning and polishing of the rods and cleaning of the holes that the rods ride in. Assembly also took some time. With the rods unstuck I had enough room to use a 1/4" socket drive and a Phillips bit. The ratchet made it a lot easier. It was trial and error until I came up with a technique that got all the parts in place and let me screw everything back together. It works perfectly now.
Thanks for everyones help,
Ralph Lipeles
