Re: Box Joint Jig
Alan in Little Washington (NC)
Box joints rely on a perfect fit- it must literally be set to a few thousandths of an inch. Dimpling the bar and some of the other suggestions mentioned here should help. I use 3/8" X 3/4" cold rolled steel from my local metal supplier for runners on all my jigs.
Besides the bar, there are other common causes of bad box joints so make sure the guide pin width and space between the guide pin and the blade are precisely the same. Don't try to work backwards- start with the size of notch the blade is cutting, not what you think or it is supposed to be cutting, and work from there. Use direct sizing, try not to use calipers when sizing the guide pin and setting the gap.
All that being said, something new is just around the corner that solves all the problems of existing and homemade jigs.
