question about fastening metal wires to make cage
Bill Tindall
The need: a cage to set on a low sided trailer to put lambs in to haul to market. Think very large "dog crate".
Plan: There are things called "cattle panels". They are 4.5 x 16' panels of heavy wire mesh in about a 6 x 6"grid. I would like to make a cage from pieces of these panels by fastening sections together somehow.
The need: some device for fastening the panel wires together to secure them into a cage(box).
Thoughts: I have seen "c" shaped metal pieces that are crimped closed to secure two adjacent wires together but no idea where to get such a fastener or crimping device. I could use "radiator hose" clamps, those stainless steel affairs that tighten a band with a worm screw. But that would be expensive unless there was a source of cheap clamps. Heavy duty cable ties would work temporarily. Maybe there are kinds that hold up better than what I have.
Do you all have any ideas?
Re: question about fastening metal wires to make cage
Galen Vetterick
Hog ring pliers and hog rings join wire cages. I guess an upholsters hog ring pliers might work but I think the rings are a little lighter and not stainless steel.
The old pliers I had had a thumb screw you use to set how far you crimp them closed. You can adjust for your wire size and set them tight or loose.
There is no squealing involved with this application.
What about hog rings or
Gary Smyth
aircraft wire spinning pliers. Both are relatively inexpensive. If the spinning pliers are used you can snug it down real well and snip it close. I cover the snipped portion with paintable tool handle plastic to keep from snagging on the clipped end.
Don at Central Illinois
That was my first thought also.
Re: question about fastening metal wires to make c *LINK*
John McGaw
OK, so you are talking lambs, not bunny rabbits, but the theory is the same. Take a look at the cage-building stuff here. The C ring and crimper items will probably be of the most interest.
http://www.bunnyrabbit.com/price/cagequip.htm
I'd vote for looking into the hog rings, too, if you can find any large enough; but they can be bent outward again. I don't know how enthusiastic lambs are at pushing against barriers; obviously, having lambs scattered all over the place after they push one wall open wouldn't be fun.
Maybe better would be rebar wire twisters (link below) that work with pre-bent bits of tie wire. These would provide a more definite "lock" to the closing. The pre-bent bits of tie wire I've seen end in loops, which would have less likelihood than hog rings of snagging the lambs' coats or causing wounds.
The rebar twisters and pre-bent tie wires should be available at a contractor's lumberyard or masonry supply house near you (not sure if the big boxy stores carry them - I've seen them at my local contractor's yard, but go to Home Desperate/Lowe's as little as I can).
One example of many
I have the exact tool you are seeking. There are aluminum clips made of flat stock and a pair of pliers that curls them into a circle. Oddly, I am pretty sure I can find them. My son used to raise ducks. Wild ducks. We had twenty pairs. I built him two aviaries. the setup I have I might be a little light for you, but if you put enough clips it should work. If you would like them I can send you a photo and if they suit you I will send them to you.
Be careful with wire with 6" openings. Small lambs might escape and larger ones may get their heads stuck. Dead lambs are very unsympathetic and don't bring much at market. What about a frame and some dog wire?
Dale Lenz
Re: What about hog rings or
Dale Lenz
Purchase my hog ring and pliers at the town Coop. The other pliers shown is what we called Safety Wire Pliers in the Navy. I've got two pairs, they come in handy from time to time, use 0.032 wire. The spring that makes the twisting device return is the weak link.
openings
Our local farm supply place sells "hog panels" (or something like that) on which the openings are smaller - horizontals closer together at the bottom than at the top. These might be helpful.
openings not a problem
Bill Tindall
A 120 pound slaughter lamb will only fit through a cattle panel mesh after it has become lamb chops. Everything about the cattle panels makes them ideal for the job, if I can fine a means of joining the heavy gauge wires. I will see if there is a local supply of galvanized or stainless steel hog rings in a size that will circumnavigate two cattle panel wires. If not, the suggestion of double loop wire ties looks to be a reasonable solution till they rust away. I checked that option out and no coated option is to be had locally.
Bill Turpin in WNC mountains
I thought this was a woodworking site. What about wood slats put together at whatever openings needed?
the result weighs a ton.
Bill Tindall
I used to have a lamb hauling trailer fashioned as you describe. But I have consolidated my trailer collection to one multitasker- a low flat bed with short sides which hauls wood, lime, rock, mower,and I hope lambs.
We sold some lambs last year to a person who arrived with a similar trailer and a "cage" fashioned from cattle panels. It was clear this cage was the most practical(cost, ease of fabrication, weight, longevity) solution for the need.
How about Copper or galvanized wire?
You're probably looking for a swaging set which looks like a bolt cutter that clamps and crimps a soft steel alloy to make loops in steel cables. Might try Tractor Supply
PS
You could also use small U bolts
Bob Entwisle in NJ
I agree with the Hog Rings.
I've used em on wire fencing. I modified a pair of pliers by grinding a groove in the jaws for crimping the rings closed.
Bob in NJ
http://www.mcmaster.com/#standard-hog-rings/=cgodw0
that's it...perfect...thanks
Bill Tindall
the larger size is just what I need for the thick wires.
One more Idea.....
I grew up on a farm and we had to put up and repair fences. We had a tool that was basically a piece of flat steel bar stock bent into the shape of a "J". There was a notch in the side of the leg of the J. You hooked one wire in the u of the J and the other wire in the notch, then you spin the J around the wire, wrapping the second wire in a tight spiral. It made a perfect spiral that looked factory made. If you had one of these you could wind fairly heavy wire around the wires where the sections join. Hard to explain, but it has about a one minute learning curve.
I bet Tractor Supply Or Agribusiness would know about these. You could make one if you had even rudimentary metal working skills.
Wire twister! *LINK*
Tom Dunlap
This?
Plain wire can be used or there are made-up wires with factory made eyes to hook onto the twister
Tie wire twister
A solution at hand
Bill Tindall
Home Depot, in the fence section, had 12 ga galvanized hog rings in a sufficiently large size. Perfect. When I was searching sources I was pointed to cain link fence suppliers and thence to Home Depot. Even the person that works that area didn't know they had them. Thanks to all for suggestions.
mdclor
Bill,
In a previous life I used hog panels to keep sheep where I wanted them and they worked fine, except one lamb stuck his head through an opening and was too stupid to pull it back out. I ended up cutting the restricting horizontal with a hack saw to get him loose. Did I mention that sheep are stupid???
I would cut the panels to length and use short pieces (maybe 4-5") of #9 wire on the intersections to hold them together. You will need pliers (fencing pliers work well) to bend the #9 back on itself and then give it a couple twists to secure it. Cutting #9 is best done with a bolt cutter. Let me know if any questions.
HTH,
Merle
disagree
Bill Tindall
I have raised sheep about 30 years and have learned that they can do things that appear stupid to humans but they are definitely not stupid animals, especially when it comes to food and escaping enclosures. Once escaped they know exactly which plant is either most tasty or most treasured by the farmer or farmer's wife. They will remember the location of food sources for months, if not years, handy when escape is expected to be detected and there is only time for a bite or two.
But best of all......they taste good.
