OT - computer questions
I went to the computer store to pick up a mouse the other day.
While I was there, I asked about my old, slow desktop computer. The guy there suggested that one of the reasons why my desktop was getting slow was that the hard disk was gradually deteriorating. He said that as a disk drive gets older, the continuity suffers and the sectors may be bad. The computer is having to "skip" all around the disk to access relevant information.
Okay - I can sort of agree with that notion. It sounds logical.
The other thing I noticed was the 1 terabyte external hard drive ($90). Iseems to me that such a drive would be the perfect thing for an external back-up device. Much better than the 4 gb flash drives or whatever. Thoughts on this?
TIA
Re: OT - computer questions
Charles in Mtl.
one way to check if the disk is ok is to defrag it delete temporary files which accumulate over time. Its true some sectors may go bad over time but when drives fail it usually means they just stop working. There are several utilities that can check the "health" of the drive if it worries you. HDTune free edition is a good one. If you buy a new drive he will need to make sure the computer will recognize it as some the older computers only "see" drives up to a certain capacity.
external backup
Charles in Mtl.
sounds perfect for an external backup drive on a USB port. You will need to buy an enclosure for it also.
Re: external backup
Jerry Nicholson
I think he already said it was an external drive ;) ;) ;)
Dan Donaldson
I am going to make a couple of assumptions: First, that you are running some flavor of Windows, and second, that You probably have not formatted the drive and reinstalled Windows since you bought the machine. If these are valid, then the most likely cause for the slowdown is that the registry has a lot of junk in it, you may have a boatload of tilde temp files floating around, and the disc needs to be defragged. You can make a lot of improvements on old Windows installations by saving your data, formatting the drive and starting with a fresh Windows installation.
Ken Garlock, Collin County Texas
Good evening J, or is it L, some people like to be called by their last name.
If you PC is running slowly, I would start by deleting the cookies. Then I would go over to the the system tools and run the de-frag tool. If that doesn't help, down load a copy of CC-Cleaner. it is an excellent garbage collector, and will also clean up much of your registry. Another option is down loading Registry Mechanic. Registry Mechanic will clean up things you never knew existed. Install programs are bad about leaving crap in the registry, Registry mechanic will clean it up. Oh yes, it does make back-up of what it removes, so you can c y a.
As for the guy who said old disks have lots of re-assigned tracks due to errors, should take a look at a new disk, they come out of the factory with multiple alternate track assignments.
Finally, start making backups Get a tool that will do a full disk copy and allow you to restore an individual application, should the need arise.
Good luck,
Ken
I use CCleaner
I think I will get the external hard drive, copy everything and then do a complete reinstall.
When I ran Chkdsk and HD tune, I found no errors.
